If all connections and power rails are good, then it's possible the chip is defective. I think they're quite easy to kill with ESD/excess heat from soldering.
Can't see from your photo; did you solder JAOUT_Line Receiver to J2 instead of J1_AOUT_NG?
Did you remove the ICs from the Line Receiver when testing with the "direct" Core connections?
The AOUT boards have an op amp with no output resistor. Every time you plug into a socket, the tip shorts to 0V. But TL074s are fine with this (they do heat up though!).
Some people will say the the typical output resistor isn't needed anyway and it leads to pitch errors. There are also fancier output schemes with the limiting resistor in the feedback loop.
I've never actually ordered anything from Aliexpr., but I know others have.
The build info/parts etc. have been on the wiki for a while now:
http://wiki.midibox.org/doku.php?id=wcore
Looks like it's about the same to purchase through eBay (recommended over Ali).
Best,
Andy
Please embed the pictures here so when the offsite doku goes bad they'll last at least as long as the forum does.
You have the headers in backwards. They should go on the underside of the board. This will also allow you to put the panel on properly.
Try to get the main CS working before connecting any other modules (DOUT, AOUT etc.).
I think the CV staying at the last level is the expected behaviour. Also "off" would mean about -5V in a bipolar mode...
If using a modular, then just pull out the patch cable :). Or solder a switch inline with the cable to shut it off when it's not required. Most modules I know will attenuate (full anticlockwise is 0) or attenuvert (middle is zero), so these are options too.
This one is also quite cool. The bit at the start is funny as Matthias (also drums) is describing his friend Simon playing a joke on him. Somehow John (bass) and I set up the chord progression and off we go. The end is a bit rambly but it's a jam after all!
Thanks! The sound at the start is the Rhodes Chroma as are the later pads. I can't remember if it was going through any effects, but it's probably the raw synth. The bass is Moog Voyager.
I have another one that sounds a bit like a didge, but it's just a Sherman Filterbank 2. It's pretty rough though, so I'll save your ears :).
@Smithy, if you're thinking of a SEQ V4+ build, I'd hold off. Often the cheaper OLEDs are about 5mm taller, and I think we need that for the V4+. For colours, the best approach is to use a white one and put a plastic sheet (gel) in front of it.
