2,516 -
147
SmashTV Core STM32F4 + MIDI_I/O Module PCB
latigid on replied to fundamental's topic in Parts Questions
This one for M3! 534-7695 Also snap in terminals, might be easier to solder -
If somebody (Tim?Mike) has part numbers for the more esoteric connectors like the SD card slot and female pin headers, that too would be awesome! Edit: perhaps I should just read the post above! -
Where are you located? I have an LPC Core board that I won't use.
In theory I think it should, although you may run into latency problems if you cascade too many chains. Are you planning to use two different cases? Can you not just run two Cores? Also AOUT is limited to 8 channels for most applications at the moment.
Pre-filter input for processing external instruments. You can also add feedback here to increase filter resonance/drive. These are what the pots on the back of most MB-6582s do.
Let's buy TK a ridiculous amount of beer for Xmas
latigid on replied to borfo's topic in MIDIbox SEQ
Ouch, maybe hide the email from the spambots? I'm already sending him PCBs for Xmas, I guess these will be on me :) -
I started with Altitude's schem (thanks!) but changed basically all of the parts in the end. I've gone for a DIP20 MAX525 because there was plenty of space. This won't be too cheap -- the DIP20 version is about $10 more than the SSOIC20, and this is just a 4-channel board keeping in line with my other projects. The dimensions are 100x58.4 mm I've cascaded the J19 connections (hopefully not too close together) and added a chip select line for RC1/2. GND and AGND are on separate planes, joined at one point. Each output has a scale control (1/4 TL074) and a second stage (1/4 TL074) to either buffer (0->10.67 V) scale (0->5.33 V) or offset (-5.00->5.67 V). This can be configured with jumpers or a second control board. The offsets are generated by LM4040 precision references. This should be better than dividing the 12 V rail which can be fairly noisy. Each output then has a divider pot for attenuation. Power is via Eurorack style 2x5 DIL or AOUT style 3 pin SIL headers. Questions/comments are welcome.
FYI: new TTSH will come soon (1-2 months). There was somebody on MW who was looking to buy unused kits.
One annoying error with the AIN board: changing from LM7805 to LM4040 I've misplaced the regulator (should come after the series resistor). I don't think it's fatal as there are a few spare headers for Vref. New things: here is a simulation for a 0-10/0-5/-5-+5 V offset circuit for a MAX525 based AOUT. The aim is to build a circuit following Altitude's but probably through hole for the most part.
Ich kenn nichts so gut Deutsch, aber: Ich sehe ein paar Fehler: Vias auf Pads IDC Steckverbinder werden groessen als dem Headers sein. Unrouted Anschluss Man kann die "SSIP" Widerstandnetwerks bestellen, http://www.digikey.com/product-detail/en/EXB-H6E221J/R5221CT-ND/115784 http://www.ebay.com/itm/QTY-50-EXBH8E682J-PANASONIC-8-SSIP-SMD-BUSSED-RESISTOR-NETWORKS-6-8K-Ohm-/111481425911 Fuer die kleines Platten, warum nichts ein DINX2 machen? Dann man kann die 74HC165 in einer Linie montieren.
So, as the STM32F4 ADC reference is 3.0 V, the first amp stage must be decreased. I think it's safe to keep the supply rails at 3.3 V, as the STM32 pins can take up to 3.6 V. Anything above 3 V on the output will clip the top of the waveform though. A 59k feedback resistor in the first inverting stage will turn 5 V into 2.95. With 59k in the first stage, a cap value of 1 pF will result in a first order filter with a corner frequency of 2.7 MHz, 10 pF would give 270 kHz, 100 pF 27 kHz etc. Fc = 1/2*pi*C*Rf. So I'd recommend a 10 pF cap here. A filter on the second stage is probably not needed but I'll leave the pads in. Other recent additions (I won't bother with a picture): 12 and 3.3V travel through the same interconnect cable as the AINs. 5 V was replaced by an LM4040 precision reference The 4427 driver can be powered by any voltage (over 7 V I think) via the 12V rail or an external source anywhere up to 18 V. The trigger thresholds are less than 0.8-1.0 V for off and greater than 1.5-2.4 V for on, which are easy to get from our DOUT module. The supply voltage then sets the gate level. Switches are more centred between the jack sockets with the 2x8 DIL header at 90°. One central mounting hole was added so the boards can be stacked one on top of the other. This could be better for small breakout boxes rather than full 19" panels.
The spacing is a bit tight with 700 mil between the pots. I've enlarged the board to 100 mm and spaced the pots 900 mil/22.9 mm apart. With a bit of suggestion from Altitude I think it will be better to use an LM4040 reference in place of the linear Vreg. I will also include 4427 chips on the control board to optionally select 12 V for two (or maybe all four) gates... Edit: because I will use the same board as an output module for AOUT (+atten.), CV range switch, and gates with LEDs
A bit harder from this side!
The DOUT R5 board has the following pinout per shift register: NC D6 D4 D2 D0 VS D7 D5 D3 D1 This needs a bit more consideration in order to connect two control boards to one SR.
Many thanks! That's a good idea for sure, but for now I prefer to keep it simple. Also attenuation to zero is much easier with a unipolar control. I don't yet know how TK will handle the software side of things and perhaps the levels will be limited in any case. Here's another installment: a control board to work with the AIN board above. My idea is to panel mount the AIN board via the pots, and have this at a right angle above. It includes: 4 sockets for AINs, connected via a ribbon to the bottom board 4 switches (ON-OFF-ON) to control the input ranges. I chose 2x 16-way IDCs which will span over two of the jumper spaces below. 4 outputs from a DOUT module. These will be either four CLOCK OUTS, or two CLOCK OUTS, one START signal and one CLOCK IN (see below). These are connected to 3.5 mm sockets but I have also used Schmitt triggers as LED drivers. The 74LVC14A chip (SMD) runs off 3.3 V but has 5V tolerant inputs, so it can be run directly from the DOUT. 1 CLOCK IN routed to two Schmitt triggers in series (logic level preserved) and the same LED as above. This is jumperable so the correct function (CLOCK IN or OUT) can be selected. I think 100k resistors should provide enough current limiting to protect the chip. The 3.3 V signal can then be connected to a DIN module for clock functions. If I've missed anything, please let me know.
Hey, is this an original build? If you want a SEQ V4, I highly doubt anybody will trade down to a non-working V3. Presumably you have a veroboard CS and not the Wilba PCB installed? The good news is that you can swap out the Core and have a V4 right away using all of the original control surface. There is a page on uCapps.de detailing the upgrade.
