TK. Posted September 17, 2008 Report Posted September 17, 2008 We are currently working on the upcoming ARM based MIOS32 platform, and MIDIbox SEQ V4 will be one of the first projects which I will use for a feasibility study. It's too early to give you detailed informations about the final hardware decitions (and this topic shouldn't be discussed here), but the design goal is to find a solution which will only require to replace the MBHP_CORE module by a new one (MBHP_CORE_STM32), the remaining hardware can be re-used, no frontpanel changes are planned, etc.Expected upgrading costs: ca. 25..40 EUR (maximum)The new platform will allow to overcome the limitations of the PIC, especially the available memory and the execution speed. MBSEQ V4 will be implemented in C, so that it will be portable to different ARM derivatives (we will probably take a Cortex M3 based device), and even to a PC so that people are able to evaluate the firmware before building the hardware (given, that somebody else programs a graphical user interface)Update: GUI now available for MacOS - Cocoa is pure fun :)A first release can be expected in Q2 2009; I've some rough plans which features I could add in addition to the existing ones, but I wonder which ones you would like to see.My ideas so far:integrating the nice features you already requested for MBSEQ V3 (see bottom of CHANGELOG.txt and the MBSEQ V3.3 thread)more steps per track, at least 12816 additional tracks for drums/percussions only, improved editingpatterns stored on SD-Card, so that simple backup/file exchange is possible w/o using SysExMIDI file import and exportintegrated MIDI file playersupport for USB; MIDI USB and/or optionally COM protocol (for OSC packages to a proxy)maybe also support for Ethernet (OSC and/or MIDI)using OSC not only for sound triggering, but also for remote controllinglive recording with different quantisation strategiesindividual track/pattern/song/mixer channel namessend SysEx patches to your synths (stored on SD-Card)Let's fill the memory ;)/Update: Comments to requested features herehttp://www.midibox.org/forum/index.php/topic,12186.msg105818.html#msg105818Best Regards, Thorsten.
moogah Posted September 17, 2008 Report Posted September 17, 2008 WOW. You just made my day TK. I'll have to put some stuff on pause while the details of this new core get fleshed out.. some ideas I had shelved may be possible now!Most of my wishlist is already covered in other peoples suggestions.. but I'd like to add that there is no base resolution for the sequencer which I'd consider too high! With MIDI file import being a possibility, it would be very nice to be able to bring in recycled .mid files for beat chopping without loosing their original feel.. something even the MPC's can't do. This does require a very high resolution tho, and may simply be impractical for a hardware sequencer.
arumblack Posted September 17, 2008 Report Posted September 17, 2008 Perhaps the possibility to slice beats on the seq itself.....would require some sampling hardware though. well, at least sample playback hardware, I personally would have no problem only being able to import the samples from SD cards, with no recording. Longer patterns would be great also, already on your list.Touch screen ?
julienvoirin Posted September 17, 2008 Report Posted September 17, 2008 more steps per track, at least 128 patterns stored on SD-Card, so that simple backup/file exchange is possible w/o using SysExMIDI file import and exportintegrated MIDI file player live recording with different quantisation strategiesindividual track/pattern/song/mixer channel namessend SysEx patches to your synths (stored on SD-Card)all these features please me a lot : it will replace my MPC ^^Do you plan to play different sequences of different length at the same time i mean A and B play simultaniously, A is 4 bars, B is 6 for example)?a Chop Shop function for each track (real time remix) ?That's great, thanks !
Echopraxia Posted September 17, 2008 Report Posted September 17, 2008 more steps per track, at least 128Does this mean 128 steps in a bar for micro editing? I was thinking replace the 2x multi triggers of the notes and be able to put extra notes in between the 16 steps but not have them be dependent on any of the 16 steps. I would like to make sounds that speed up and slow down by making a bunch of notes tightly packed together. Maybe use forward and backward keys to advance to next micro step while editing.I was also thinking to have way more layers per track so we can have orchestral polyphony and 16-32 CCs per track for autechre editing.I.E pan, notes, vel, aftertouch, and all the other CCs per track please. I think this would make for big yippie!And no limit to a patterns length. Aleast if it could be 8-16 bars for string stuff.And if that happens maybe we could get a small lcd that displays all the tracks kinda like on the tr-707 and the MBseq multi led expansion.Don't forget about the real time note retrigger functions we discussed earlier.Could we control tempo of indiviual track and have tempo spring back to normal when special button is released/pressed?Is it to much to ask for more than 16 tracks. Like 64 maybe :)Now we need ultracore x32 before I even use the first one.TK your freakin awsome.I will now stfu.
stryd_one Posted September 18, 2008 Report Posted September 18, 2008 One thing I would suggest is loading more than 4 tracks into ram for editing, which would enable people to use the bigger BLMs that have been so heavily requested.Echo: you can already do the many-modulators thing with extra tracks ;)Needless to say I'm a big fan of individual tempo control per track, but as we already know, doing so with unusual meters (time signature/divider/etc) introduces some interesting challenges when you want to have independent track tempos but still keep them in phase (and even more so when you take things like realtime retriggering of tracks and loopback ports and such). It's easy enough to solve, but does cause a performance hit, so I'm not sure it's for everyone... That said, the chips we are playing with at present do have a hardware divider that will significantly reduce the overheads of such a system, so maybe it won't be so bad...
bugfight Posted September 18, 2008 Report Posted September 18, 2008 personally i'd rather see this seq stay a step seq...the usage and editing requirements are quite different for a high res midi seq,i think enough so that such a thing would deserve it's own application...however being able to delay or advance steps in time by small amounts within a track could be very cool.+1 on the phasing thing (different track lengths in parallel)this is very fun thing to use on audio loopers anyways...
Futureman Posted September 18, 2008 Report Posted September 18, 2008 LABELS!!!!YAY!I would also prefer to keep it as a step sequencer... Maybe an MPC style sequencer could be a different project all together.I'd also like The BPM to be able to increment in 0.1 BPM too.. (Thats a pretty small feature)(1 BPM is too coarse when lineing up longer samples)RegardsMike
H2O Posted September 18, 2008 Report Posted September 18, 2008 Just some random thoughts to throw out there... (feel free to ignore! ;D)DMX output - why separate audio and visual sequencing? I gather speed and memory was the main issue with DMX in the past. (Let's be honest, we all love http://www.youtube.com/watch?v=UtnUMpykQLc!)SEQ scratching - scratch / jog / across a pattern (unless of course you already can, I haven't built one... yet!)Big colour LCDs - would take a bit of GUI programming thoughMIDI over WLAN - hey, why not think crazyLove the idea of channel names. I'm wondering where and how they could be displayed.Also love the sound of C! (ASM scares me a bit...;))
/tilted/ Posted September 18, 2008 Report Posted September 18, 2008 DMX output - why separate audio and visual sequencing? I gather speed and memory was the main issue with DMX in the past. (Let's be honest, we all love http://www.youtube.com/watch?v=UtnUMpykQLc!)Outputting DMX is not a massive chore in terms of speed or memory. A full universe of DMX is only 512 x 8 bit numbers, with some start/stop etc thrown in. So, to store all these values in RAM would only require 512 bytes. The transfer speed is only slightly problematic (250kbaud).The real issue with DMX is that it is not state-based like MIDI, so you must keep the stream active at all times, or the state is dropped.(ie, with MIDI, you simply tell a synth to start playing a note, or move a controller to a position. It is assumed in the protocol that the synth will keep doing what you last told it, until you tell it to stop).Some DMX controlled devices will retain the last complete packet if the stream is dropped, but this is not specified by the protocol (though it has saved my ass many times ;) )Edit: (So, what I'm saying is that DMX output has always been possible, but the core would not be able to do anything else... like running a sequencer application...)
TK. Posted September 18, 2008 Author Report Posted September 18, 2008 Partly you are requesting features, which are already implemented.Hope that other people don't feel conused about that - everything written in the Manual is true ;)Best Regards, Thorsten.
stryd_one Posted September 18, 2008 Report Posted September 18, 2008 I'd like to see tracks outputting to loopback ports, processed before other tracks....
moogah Posted September 18, 2008 Report Posted September 18, 2008 the usage and editing requirements are quite different for a high res midi seq' date='i think enough so that such a thing would deserve it's own application...however being able to delay or advance steps in time by small amounts within a track could be very cool.[/quote']Thinking about it a bit longer, I agree with you. A step sequencer is not the proper application for beat slicing 8)
Echopraxia Posted September 19, 2008 Report Posted September 19, 2008 Echo: you can already do the many-modulators thing with extra tracks But why not just have more for each track rather than using more tracks for just one sound ect..?About tempo control issues. I was saying to maybe have an F function button to control the usage by reverting the tempo back to normal sync when released/pressed vice versa maybe user selectable. Individual tempo would still be cool but I was thinking of temporary changes that would sync back up. I hope I am explaining myself well.Maybe this feature would only be good for crack heads??? I am not sure if it woudl be cool in the long run though.personally i'd rather see this seq stay a step seq... the usage and editing requirements are quite different for a high res midi seq, i think enough so that such a thing would deserve it's own application... If your talking about micro editing between steps I can see your point here. Maybe just having long patterns like 16 bars long at 128th would work just aswell ;)I still like the idea of retriggering steps or multiple steps for breakbeat stuff and fills. That was were the tempo thing came up as I was hopeing to retrigger steps and adjust tempo at same time.labels sound very nice too for naming CCs, patterns ect... USB keyboard input anyone?I don;t know much about the Song mode as I have only tinkered with V3 alittle for testing but does it save only patterns used in the song? I was thinking you could still load other patterns into the song but then just resave the song. Is this how it is already?
TK. Posted September 19, 2008 Author Report Posted September 19, 2008 But why not just have more for each track rather than using more tracks for just one sound ect..?The live editing step sequencer concept requires static data structures stored in RAM. Let's say, each track would offer 16 layers with 128 steps, this would lead to a memory consumption of 2k for each track, and 32k for 16 tracksBut the planned processor offers only 20k RAM (update: 64k RAM, 512k flash cost US $4 more - we will take this one)Another issue: storing 32k on SD Card would lead to unwanted latencies on pattern changes, regardless how much RAM is availableBut a 4th layer makes sense (I'm missing it as well)About tempo control issues. I was saying to maybe have an F function button to control the usage by reverting the tempo back to normal sync when released/pressed vice versa maybe user selectable. Individual tempo would still be cool but I was thinking of temporary changes that would sync back up. I hope I am explaining myself well.Maybe this feature would only be good for crack heads??? I am not sure if it woudl be cool in the long run though.-> live control pageBackground story: two weeks ago I spent several hours to optimize MBSEQ V3 in order to get some free memory for this page. Especially because I've also some cool tempo/step progression manipulation ideas in my mind which could lead to very nice breakbeat effects as well. The page should combine the suggestions - a lot of parameters and trigger buttons so that everybody can search for his favourite ones.But at the end I only saved ca. 700 bytes - not enough.This was the day were I decided to move to a new platform...If your talking about micro editing between steps I can see your point here. Maybe just having long patterns like 16 bars long at 128th would work just aswell ;)And a zoomed view, so that you can get an oversight over all bars.I still like the idea of retriggering steps or multiple steps for breakbeat stuff and fills. That was were the tempo thing came up as I was hopeing to retrigger steps and adjust tempo at same time.See above - I've some ideas as well, it won't be forgotten.labels sound very nice too for naming CCs, patterns ect... USB keyboard input anyone?haha!USB slave mode onlyI don;t know much about the Song mode as I have only tinkered with V3 alittle for testing but does it save only patterns used in the song? I was thinking you could still load other patterns into the song but then just resave the song. Is this how it is already?Sure - the pattern slots not used by the song are free changable.Best Regards, Thorsten.
stuartm Posted September 19, 2008 Report Posted September 19, 2008 ...My ideas so far:more steps per track, at least 128..individual track/pattern/song/mixer channel namesYou already got my two biggest wishes. ;)
Echopraxia Posted September 19, 2008 Report Posted September 19, 2008 Let's say, each track would offer 16 layers with 128 steps, this would lead to a memory consumption of 2k for each track, and 32k for 16 tracksBut the planned processor offers only 20k RAMA track is considered the same thing as pattern? And 128 steps would be 8 bars if I am understanding correctly? Sounds good to me.And a zoomed view, so that you can get an oversight over all bars.Zooming out to see every track and how many bars there are all at once? Is there an option to change how the track moves to the next track. I.E imediately or at the next bar option. I guess sync would become a problem though but not by much.Also maybe add a delay to the live trigger page which would repeat notes and fade the velcoity on the repeats or whatever customizable to scales ect...Do you think backwards scrub would now be possible? :DWhen ever I have more time when I am not juggling three kids, wife, friends, work,and music I really want to contribute to midibox in some way.
TK. Posted September 19, 2008 Author Report Posted September 19, 2008 A track is considered the same thing as pattern? And 128 steps would be 8 bars if I am understanding correctly? Sounds good to me.A pattern consists of 4 tracks, and it depends on the selected resolution (clock dividers) if 128 steps are playing 8 bars or less or more.E.g., with MBSEQ V3 you are already able to play 16 bars with a single track if a clock divider of 64 is selected. Two notes per bar are played in this case. This is especially nice for a track which plays the base note for other tracks (note event sent via loopback to transposed tracks)You can also already select a clock divider of 4, which results into quadrupled speed. 32 steps are processed in 1/2 bar - but they are played superfast, so that microtimed beats can be easily created. Especially once the progression parameters are used in addition (so that for example the track will be varied over more than 4 bars) very nice effects can already be achieved.Another point (to answer some requests above): you can also already select odd divider values and predividers for different time scales. The track length can already be varied.All this for each track individually! - so, no need to overwork the concept here. There is only a strong need that people begin to understand the given possibilities ;) (sometimes I've the impression, that most of you only use straightforward tracks without different timing/length/progression values)In MBSEQ V4, we will get more steps, but I think that you can calculate by your own, how many bars can be played depending on the selected clock divider values (== resolution)Sorry, no time anymore to answer remaining questions - I've to prepare for holidays ;)For more requests I cannot say if it is possible or not anyhow, since the evaluation phase (checking the possibilities of the new micro by programming a lot of code) will take ca. 6 months. Thereafter I should have enough experiences to give realistic statements.Best Regards, Thorsten.
TK. Posted September 19, 2008 Author Report Posted September 19, 2008 Some last words to the ideas behind the zoom functions: with 128 steps you would have to trigger the "Step View" (F3) button multiple times switch between the different 16 step pages. Thats unusable.This button will get a different purpose: press&hold it to zoom out the 16 step view - you will see an oversight over all 128 steps. Now press a GP button to zoom into a view.I'm also thinking about an alternative "scroll view" function by utilising the datawheel.Very quick page changes should be possible this wayBest Regards, Thorsten.
mattias Posted September 20, 2008 Report Posted September 20, 2008 A Gate time Trigger or Layer to vary the time intervals between the steps. The steps can be set within the range from 1/384 to 16 1/1 notes. Like on the Scritty... or even higher resolution..Midi processors for internal routing... with midi fx... LFOs and midi filters.... maybe the arp. should go thereMore random stuff... rotate....skip closed gates ... random move active gates selected and or random chance by percent... There is alot of crazy stuff that can be done here... Maybe 16 tracks for internal loopback so funktions can be muted / toggled on off. This would be like dynamic editing... the seq programning itself. So we can have tracks triggering Track directions, Track direction progressive parameters, clock divider for each track, normal and tripled, groove quantiasion start and stop of sequnces and loop points.I think all my ideas can be done with 16 internal loopback tracks like the 16 new drumtracks!!YES lan midi please.. wifi?? Possible??I don´t mind features like 128 steps... but please keep it a stepseq... 64 steps is fine even 32 as it is now..A memory place holder for timebase and groove... using gp buttons to change the tempo and groove quickly...Drummaps.. yes please!! Nameable!!More CC layers in the mixer map...Maybe a daw mackie/LC controller... maybe not keep it a seq...Midi sync. delay calibration.. Clock sync delay in ms... from say -30 ms to +30 msMaybe my ideas are to crazy but think about it.
Twin-X Posted September 30, 2008 Report Posted September 30, 2008 Currently only MacOS X version plannedNot fair Thorsten ;)
bugfight Posted September 30, 2008 Report Posted September 30, 2008 Not fair Thorsten ;)honestly, i think things like this are far better off with dedicated versions for each os.so we pc users will have to add our own user interface code, i say good, java sucketh...
Phattline Posted September 30, 2008 Report Posted September 30, 2008 Wishlist? I make Livejams and liveacts...so I want a great very very very easy to use live toolOK, very importent, 1st wish Midimixerfunction + optional Hardware options for that--meens:Fader1: the whole Volume (midi volume) of the first track is controlled (undependet of the single step volume, you can fade it the track out)Fader2: the whole Volume of the 2nd track...So now If Fader 1 & 2 sends on the same midichanal. You can mix to Sequences very smoothly, and you can jam very perfect (I have done this in Ableton and it is very good for jaming)of course for all Chanals, it would be cool too have velocity controll!1st Ideata ta ta da ;D Motorfadersupport & Motoerfader-steptunecontrollhttp://www.phatline.at/Phatline-jamsetup-setup.3gp (in german language---but hopefully TK knows whtat to do with that idea ;D hopefully) think on it---yeah a blind man could make electronic sequence jams ;D...means:You have 16 Motorfaders in a row, The 1st Motorfader controll the first pitch of the first step..The 16th naturaly the 16th step, and when I press a button, I can controll Step 17 to 32.... over the Motorfaders are 2 rows of Buttons (32 buttons) 1row for Accenting, 1row for Slide (or to make a note so long that it ends with start of the new note)Special function Buttons (take for that the 32 buttons and a shift button!) for this Idea are: The great "Fader-steps"-buttons ;D --- The downer Row of the 32ButtonsBy pressing Step1+shift, you get a 16step sequence where every motorfader controlls only one 16th stepStep2+Shift= you, you get? yeah alright--- you get a 32Step sequence, where every motorfader controll 2 steps...and so on...Step9+shift= it would be nonsense to make such long sequences---I think ther would be cool: the Ta ta ta ta "polyphonic mode"The Motherfaders are now splittet in 2 Sections. 8 Faders for the lower sequencepart, 8 for the higer sequence part. Step9+shift= you will get a 8steps dualphonic sequence,Step10+Shift= you will get a 16 Step sequence- where every motorfader controlls 2 steps....and so onby activating now Step2+Shift againg, you will here now the lowerpart of the poly sequence and after that the higher....and so onThe great "Sequence-Type"-ButtonsThe upper row of the 32 buttons, are for the sequence Type: (like arpegiator types ---up down sample hold..) By pressing 1+shift you get a 32th sequence- 2+shift= you getting a 16th sequence, 3+shift=8th-offbeat, 4+shift=8th-onbeat, 5+shift=only Step 5 and 13 are controlled from Motorfader 1 and 2....6-9+shift=user definied sequence-styles like: Step 1 2 3 8 9... controlled from Motorfader 1 2 3 4 5 (the steps between are pausend---and the sequence get longer of course...because you dont loose any notes---they are only shiftet.....that rule of course is also for all other shift functions)10+shift=-1Octave for the whole sequence11+shift= No octave shift for the whole sequence12+shift=+1Occtave for the whole sequence13-16+shift acts as a polyphone pitch shifter.... (the higher part of the poly sequence-getting shiftet higher--but not the position of the faders---only the notes)14+shift=+1Octave13+shift=no octaveshift15+shift=+2Octave16+shift=+3OctaveA 3rd Function button make also sense..., to short the Sequence, so if you pressStep1+3rdSwitch, Only Motorfader1 will be looped (in poly mode Motorfader 1 and 9)Step2+3rdFunction Switch, Only Step2 will be loopedBy press 2nd function (shift) and 3rd function togehter and a Step- all Steps until the pressed step will be looped.Also needet for this Conzept: "scale" button, which switch between the pitch range of the fader, maybe, with a dualcolour LED-=> no Light: meens: 100m Motortravelway = 1 Octave, red=1 Octaves per 100mm fadertravelwayBlue=3 octaves per 100mm fadertravelway....With the functions (additional hardware features ;D ) The Sequencer woold be a so powerful tool, you can make complex monophonic sequences in seconds (and the best- you see what you are doing, and you make what you thinking)----I actually tried by Ableton live and Midibox 64 and 64 peaces 100mm Fader- to make a realtiime - very very easy to use jam sequencer----so it worked very good, in one second you have done a new sequence ;D ;D ;D ---but it was a stupid setup---no total recall---!--- but it worked. (with all the very usefull sequence style patterns!)2nd wish of course the famous "Midifileinport function" ta ta ta da :P ;D
