BLM 16x16+X PCB and case order [CLOSED/waitlist]
This is a bulk order thread for the BLM I've designed. Please post here with the quantities you desire. I will leave the order open until Sunday July 26. Note that I will give preference to those ordering both the PCB and case as the main goal is to have a complete system at the most affordable price for all.
The original concept is here:
Here is a rundown of the costs in USD:
PCBs:
Main BLM PCB: 75
miniCore PCB: 4
Mouser components (available soon as shopping carts):
BLM: 247.97
miniCore: 9.49 (excluding PIC, available from SmashTV)
The main cost of the Mouser cart is LEDs. If groups wanted to order over 1000 pieces then savings of around $45 are possible. Also the red LEDs are somewhat cheaper.
Buttons:
18 pieces of 4x4: 108, depending on where you order from.
single shift button: 1
These are available from adafruit and various other sellers like flikto.de. There are discounts available, but one has to order over 99 pieces...
3 mm acrylic spacer from Formulor/Ponoko:
~55 depending on where you order from.
Case, including shipping to you worldwide:
285 (>4 pieces)
250 (>9 pieces)
I will have to add a few extra studs to increase stability, so it's possible that these might be a few dollars more.
Hardware:
M2 grub screw, washer and nut in stainless steel: 1
20xM3 washer and nut ~3
4xwhite square LEDs to fit Bourns sliders: 1
Shipping is ridiculous from here. I will post when next travelling to the EU
Estimated cost:
CH: 12 or pickup
DE: 12
EU: 25
International: 28
Payment can be made by bank transfer or PayPal (with fees paid or 4% added for the latter)
Please update the following table as appropriate:
Name           PCB BLM   PCB miniCore  Case  Shift button  M2 hardware  4xLED
availability   9         9             -     12            9            20
latigid on     1         1             1     1             1            1
Total          1         1             1     1             1            1
Edited by latigid on
I'm in.........
Rowan          1         1             1     1             1            1
Total          2         2             2     2             2            2
Rowan          1         1             1     1             1            1
Phatline       2         2             1     1             1            1
Total          4         4             3     3             3            3
Great work!
Finally a stable design for jam sessions so that I can put the prototype into the MIDIbox museum - thanks for the great work!!!  :thumbsup:
availability   5         5             -     9             6            17
Rowan          1         1             1     1             1            1
TK             1         1             1     1             1            1
Total          5         5             4     4             4            4
Rowan          1         1             1     1             1            1
TK             1         1             1     1             1            1
Altitude       1         1             1     1             1            1
Total          6         6             5     5             5            5
Thanks Thorsten for the firmware updates to get it working and the brilliant platform to begin with! Looking forward to those other modes, whatever they turn out to be.
Och, I should say that I can either take payments via SEPA transfer (I think that's free) or PayPal. But in the latter case I would have to add 4% fees...
Just to clarify availability: I'm assuming a new run of 10 PCBs with minor trace fixes, but I might build just one more to be 100% certain... Let me think about this. And I only have 9 pieces of the M2 hardware left, which can be found in hardware stores or easily on eBay from Bolt Base. It's just for convenience's sake, and I won't need them for other projects. I think the white LEDs for the sliders work well with the Blue/Green/Cyan colour scheme, but if you like you can get other colours like red, green, orange (TTSH) etc. as standard directly from Mouser.
It's no problem to do a larger PCB run if the demand is there.
  • Like 1
I am in!
Rowan          1       1            1    1            1           1
TK             1       1            1    1            1           1
rwo                         1               1                         1         1                         1                       1
Total          7       7            6    6            6           6
Gotta get me some of this! :)
availability   4       4            -    8            5           16
Rowan          1       1            1    1            1           1
TK             1       1            1    1            1           1
rwo                         1               1                         1         1                         1                       1
jojjelito        1        1              1     1              1             1
Total          8       8            7    7            7           7
Edited by jojjelito
i'm in!
Sorry not sure for the case so no case :(
Rowan          1       1            1    1            1           1
TK             1       1            1    1            1           1
rwo                         1               1                       1         1                     1                       1
tashikoma              1                1                       -         1                      1                       1
Total          9       9            7    8            8           8
Edited by tashikoma
I' m in as well!
availability    0         0              -      4              1             12
Rowan           1         1              1      1              1             1
TK              1         1              1      1              1             1
rwo             1         1              1      1              1             1
workspace       1         1              1      1              1             1
Total          10        10              8      9              9             9
Edited by workspace
I'm in!!!
Rowan          1         1              1      1              1             1
TK                1         1              1      1              1             1
rwo               1         1              1      1              1             1
flyweight       1         1              1      1              1              1
Total          11        11              9      10              10             10
mmm sorry to see that there are no PCB's..... Does this mean i cannot join??
i'd like to have the whole pack if you can take more than 10 pcb
The new fixed pcb will be on this bulk or a new one?
G.
Rowan          1         1              1      1              1             1
TK                1         1              1      1              1             1
rwo               1         1              1      1              1             1
Grizz             1         1              1      1              1             1
Total          12        12              10      11              11             11
I'm in!!!
Rowan          1         1              1      1              1             1
TK                1         1              1      1              1             1
rwo               1         1              1      1              1             1
Please see post above: if you don't fit into a multiple like 10, 15, 20 PCBs etc, then you can go onto a waiting list for the next batch. Let's see how many are requested. Looks like a big trip to the post already!
G.
Likewise, no problem for more PCBs or cases. The PCB you will get will be a new revision.
  • Like 1
I'm in minus a case
availability    0         0              -      4              0             11
Rowan          1         1              1      1              1             1
TK                1         1              1      1              1             1
rwo               1         1              1      1              1             1
Grizz             1         1              1      1              1             1
blingy            1         1              0      1              1             1
Total          13        13              10      12              12             12
Edited by blingy
Rowan           1         1              1      1              1             1
Phatline        2         2              1      2?             1             1
TK              1         1              1      1              1             1
rwo             1         1              1      1              1             1
tashikoma       1         1              -      1              -             1
Grizz           1         1              1      1              1             1
blingy          1         1              -      1              -             1
ganchan         1         1              1      1              ?             1
Macotronic      1         1              -      -              -             -
Total          15         15             10     14             10            13
FYI, you can keep the table tidy by using the code "< >" formatting.
The shift button and M2 hardware are now maxed out. If you're still interested just put a question mark on these and if it goes over 10 I'll consider ordering more.
  • Like 1
Rowan           1         1              1      1              1             1
TK              1         1              1      1              1             1
rwo             1         1              1      1              1             1
Grizz           1         1              1      1              1             1
blingy          1         1              -      1              -             1
ganchan         1         1              1      1              ?             1
Jack            1         1              1      1              1             1
Total          16         16             11     15             11            14
Edited by Jack
Rowan           1         1              1      1              1             1
TK              1         1              1      1              1             1
rwo             1         1              1      1              1             1
Grizz           1         1              1      1              1             1
blingy          1         1              -      1              -             1
ganchan         1         1              1      1              ?             1
sbm             1         1              1      ?              ?             1
Jack            1         1              1      ?              ?             1
Total          17         17             13     14             10            15
Rowan           1         1              1      1              1             1
TK              1         1              1      1              1             1
rwo             1         1              1      1              1             1
Grizz           1         1              1      1              1             1
blingy          1         1              -      1              -             1
ganchan         1         1              1      1              ?             1
sbm             1         1              1      ?              ?             1
Jack            1         1              1      ?              ?             1
tabularasa      1         1              1      ?              ?             1
Total          18         18             14     14             10            16
I'm in with one of each.
