1,285 -
72
Everything posted by Phatline
i am working on @Antichambre dipcore... on other platforms (OSX) its working... on Linux from my side - i always have problems to set it up.... i remember: my environment variables and path is: the toolchain is in here: make --trace return me: Antichambre & Me teamviewd half yesterday but didnt find out... ...maybe someone can lead me in the right direction. thx
can underline this... a big SMD make less work then THT (when thinking on the BLM 4148 leg bending actions...)
dont matter - there are IN and OUT Lines, and they are connected thru the PCB... but put the DIN first, since it senses - and therefore it is more "sensible"
Thinking about designing my rackmount SID again...
Phatline replied to m00dawg's topic in MIDIbox SID
i also like rackmount more... you can port eagle to kicad ... search for the script "Eagle2Kicad-master" from the readme: i have sucessfully made pcb, sent the gerbers to china, and got them without failures... kicad is cool -
beeing creative in the garden ... machete me and urzeitcode.... you are flying here? and the wing in front is this also human or visa versa?
The HAARP Desktop case prototyping.
Phatline commented on Antichambre's gallery image in Members Gallery
@Antichambre : @Dipcore thx... @Case: I have UI-LEDs specially to lighten up the PCB - to Read the Labeling on it, so the Frontpanel will be Transluent. And i will make a DIY Wooden Case for the prototype - and document the Measurements, after that i have more an Idea how a Alu-Case could look... but looking on the size it would be more logical to use IRON --- heavyness... so not a real plan @ the moment @english: mine too... if i have spoken German or more Austrian, than the video hasent take 19 minutes ;) . maybe Subtitels next time ;)
- 27 replies
- 1
- cc-recorder
- controlchange looper
(and 1 more)
Tagged with:
First Prototype, First Working Firmware ( a lot of bugs, and not all features implemented) --- but enough for a teaser ;)
- 27 replies
- 1
- cc-recorder
(and 1 more)
Tagged with:
i understand, i will implement your PIN_REVERT Function THX!
595 DoutX4 c-code Pin1-7 = O0-O7 = D0-D7 but react on "MIOS32_DOUT_PinSet( 7-0, 1);" ?is there a switch that inverses that? i just for info: have a fabricated pcb here, and it would be nice i dont have to redoo the hardware, its a led-matrix > http://wiki.midibox.org/doku.php?id=cc-looper
LM1117 variable Voltage Regulator - timelapse built
Phatline replied to Phatline's topic in Songs & Sounds
das orginal video kenn ich die haben ca 2-5 und mebr cm abstAnd feldplatten ca 10*10cm und dazwischen eine petrischale mit deckel. aber wie gesagt ich möchte sagen können das stimnt, deswegen muss ichs probieren, weil ist seeeeehr i tressant -
I made this Voltage Regulator to have a variable Voltage from 1,25 to 12V.... music is from my tekkno-project "GreatFullTekk", i have different names for different genres and bands i am involved...(phatline, crimic, greatfulltekk, mjsigl, mms...) i always take own music creations for my videos... lukkely i have hundrets of it ;) i use it to drive a Hi-Voltage Generator - to field some plant seeds ( a expirment which i really want to check if there is anything true on it! - dont belivie it until you confirmed it ;) ) - music by Crimic
a lot of pictures of the build, some explaination: http://wiki.midibox.org/doku.php?id=scale-explorer#teaser some coding and real world jamsession has to be done the next months, so i dont uploadet a code yet... What it does shortly: Indicate via LEDs over the Keys, what Notes fit to the actual set Scale. I preprogrammed 240 scales, when i change the root note (on the fly) this are 2400 or more scales... programming scales, and songs is easy - just play a melody! or connect your sequencer in feed Scale-Explorer with your song! (root +2 +2 + 3+ 3+ is a scale for example... but it dont matter in which order you press it, my code detect its order) so you can indicate what scales, or notes you use in your song, or indicate what your Jaming Partner is playing on is Gitarsynth or Keyboard or Sequencer (in the case you dont hear notes as "notes" like me!) the songmode, is a "always recording" one, that means, you hit record after you played what you wanted to record... its more easy to not "try and try and try to make a perfect record" just jam, and when you think - whoo hoo that was awsome! press Record, set the loop points (which in length are always multiples of the set tact 4/4 leading into 4 8 16 32... 3/4 to 3 6 12 24...) and maybe press "purge" to clean not used notes and to shift it to Step 1... 8 Songs per scale are possible 128 scales are saved on one preset which can be loadet from sd-card, each scale can hold 8 songs/song parts, which is saved as 1 song on the SD-Card, that song is automaticly loaded by changing a scale.... So the SD-Card is pretty full with songfiles... There is a Trigger Amplifier and Schmitt trigger built in (Konga Trigger), which retrigger the pressed Keys, or Trigger Songsteps and go to the next song step while you can hold a step with Footswitch or Reset the Song to Jump to Step 1... Last Jamsession, i was sitting on this Wood-SnareDrum Instrument, clamped the trigger mic on the bassreflex opening, recordet a short snipped of the keyboard a other person played, and began to play the base, snare and "Wood" part of this 8 man Jamsession, in short time i was leading the thing, because Snare Wood Bass and its melody was fitting in this environment... i loved it! i am not a good drummer, or keyboard, but this for me was the holy grail, Electronic Music with real Humans instead of clock driven sequencers... i hope i can get you a video next month! Prepgrammed scales are: (thy have also names, but that would a bit to much for this post ;) // SCALES s8 new_scale[Nr_off_Files][128][13] = { { //File 0 {1,1,1,3,1,2,1,0,0,0,0,0,0},{1,1,2,2,2,2,0,0,0,0,0,0,0},{1,4,2,2,0,0,0,0,0,0,0,0,0},{1,7,2,0,0,0,0,0,0,0,0,0,0},{1,1,2,1,2,1,2,0,0,0,0,0,0},{4,4,0,0,0,0,0,0,0,0,0,0,0},{1,2,4,1,0,0,0,0,0,0,0,0,0},{1,1,3,2,1,2,0,0,0,0,0,0,0},//0 {1,2,1,2,1,2,1,0,0,0,0,0,0},{1,1,1,1,1,2,1,2,0,0,0,0,0},{1,1,1,2,1,1,1,2,0,0,0,0,0},{1,1,2,1,2,3,0,0,0,0,0,0,0},{1,2,1,3,1,2,0,0,0,0,0,0,0},{1,1,3,2,2,1,0,0,0,0,0,0,0},{1,1,3,2,3,0,0,0,0,0,0,0,0},{1,1,2,1,2,2,1,0,0,0,0,0,0},//1 {1,1,3,2,1,1,0,0,0,0,0,0,0},{1,1,2,2,1,2,0,0,0,0,0,0,0},{2,2,3,2,0,0,0,0,0,0,0,0,0},{1,1,1,2,1,2,1,1,0,0,0,0,0},{1,2,3,2,2,0,0,0,0,0,0,0,0},{1,1,1,2,2,1,2,0,0,0,0,0,0},{1,1,1,1,3,3,0,0,0,0,0,0,0},{1,1,1,1,1,1,1,1,1,0,0,0,0},//2 {1,1,1,1,1,1,1,1,2,0,0,0,0},{3,3,3,0,0,0,0,0,0,0,0,0,0},{3,9,0,0,0,0,0,0,0,0,0,0,0},{4,8,0,0,0,0,0,0,0,0,0,0,0},{2,2,2,3,0,0,0,0,0,0,0,0,0},{1,2,2,1,3,0,0,0,0,0,0,0,0},{1,1,2,1,3,2,0,0,0,0,0,0,0},{1,1,1,1,1,1,1,1,0,0,0,0,0},//3 {1,1,1,1,1,1,1,2,0,0,0,0,0},{1,1,1,1,1,1,1,3,0,0,0,0,0},{1,1,1,1,1,1,2,1,0,0,0,0,0},{1,1,1,1,1,1,3,1,0,0,0,0,0},{1,1,1,1,1,2,1,1,0,0,0,0,0},{1,1,1,1,1,3,1,1,0,0,0,0,0},{1,1,1,1,2,1,1,1,0,0,0,0,0},{1,1,1,1,1,1,2,2,0,0,0,0,0},//4 {1,1,1,1,2,1,1,2,0,0,0,0,0},{1,1,1,1,2,1,2,1,0,0,0,0,0},{1,1,1,1,2,2,1,1,0,0,0,0,0},{1,2,2,2,2,0,0,0,0,0,0,0,0},{2,2,3,0,0,0,0,0,0,0,0,0,0},{1,2,2,2,3,0,0,0,0,0,0,0,0},{1,1,1,3,1,3,0,0,0,0,0,0,0},{2,3,2,0,0,0,0,0,0,0,0,0,0},//5 {1,2,2,2,1,0,0,0,0,0,0,0,0},{1,3,1,3,1,0,0,0,0,0,0,0,0},{1,1,2,1,3,1,0,0,0,0,0,0,0},{1,1,3,1,3,1,0,0,0,0,0,0,0},{1,1,2,2,2,1,0,0,0,0,0,0,0},{1,1,3,1,2,1,0,0,0,0,0,0,0},{1,1,3,1,2,2,0,0,0,0,0,0,0},{1,2,1,2,2,1,0,0,0,0,0,0,0},//6 {1,1,1,1,1,2,2,1,0,0,0,0,0},{1,1,1,2,3,1,1,0,0,0,0,0,0},{1,1,2,1,1,3,1,0,0,0,0,0,0},{1,1,1,1,2,2,1,0,0,0,0,0,0},{1,2,1,4,2,0,0,0,0,0,0,0,0},{1,1,1,1,1,1,0,0,0,0,0,0,0},{1,1,1,1,1,2,0,0,0,0,0,0,0},{1,1,1,1,1,5,0,0,0,0,0,0,0},//7 {1,1,1,1,2,1,0,0,0,0,0,0,0},{1,1,1,1,5,1,0,0,0,0,0,0,0},{1,1,1,2,1,1,0,0,0,0,0,0,0},{1,1,1,5,1,1,0,0,0,0,0,0,0},{1,1,1,1,1,3,0,0,0,0,0,0,0},{1,1,1,1,1,4,0,0,0,0,0,0,0},{1,1,1,1,3,1,0,0,0,0,0,0,0},{1,1,1,1,2,2,0,0,0,0,0,0,0},//8 {1,1,1,1,2,4,0,0,0,0,0,0,0},{1,1,1,1,4,2,0,0,0,0,0,0,0},{1,1,1,2,1,2,0,0,0,0,0,0,0},{1,1,1,2,1,4,0,0,0,0,0,0,0},{1,1,1,2,4,1,0,0,0,0,0,0,0},{1,1,1,4,2,1,0,0,0,0,0,0,0},{1,1,2,1,1,2,0,0,0,0,0,0,0},{1,1,2,1,1,4,0,0,0,0,0,0,0},//9 {1,1,2,1,2,1,0,0,0,0,0,0,0},{1,1,2,1,4,1,0,0,0,0,0,0,0},{1,1,1,1,2,3,0,0,0,0,0,0,0},{1,1,1,2,1,3,0,0,0,0,0,0,0},{1,1,1,2,2,3,0,0,0,0,0,0,0},{1,1,2,3,2,1,0,0,0,0,0,0,0},{1,1,1,1,1,0,0,0,0,0,0,0,0},{1,1,1,1,2,0,0,0,0,0,0,0,0},//10 {1,1,1,1,6,0,0,0,0,0,0,0,0},{1,1,1,2,1,0,0,0,0,0,0,0,0},{1,1,1,6,1,0,0,0,0,0,0,0,0},{1,1,2,1,1,0,0,0,0,0,0,0,0},{1,1,1,1,3,0,0,0,0,0,0,0,0},{1,1,1,1,5,0,0,0,0,0,0,0,0},{1,1,1,3,1,0,0,0,0,0,0,0,0},{1,1,1,5,1,0,0,0,0,0,0,0,0},//11 {1,1,3,1,1,0,0,0,0,0,0,0,0},{1,1,1,1,4,0,0,0,0,0,0,0,0},{1,1,1,2,2,0,0,0,0,0,0,0,0},{1,1,1,2,5,0,0,0,0,0,0,0,0},{1,1,2,1,2,0,0,0,0,0,0,0,0},{1,1,2,1,5,0,0,0,0,0,0,0,0},{1,1,2,2,1,0,0,0,0,0,0,0,0},{1,1,2,5,1,0,0,0,0,0,0,0,0},//12 {1,1,5,1,2,0,0,0,0,0,0,0,0},{1,1,5,2,1,0,0,0,0,0,0,0,0},{1,1,1,2,3,0,0,0,0,0,0,0,0},{1,1,1,2,4,0,0,0,0,0,0,0,0},{1,1,1,3,2,0,0,0,0,0,0,0,0},{1,1,1,3,4,0,0,0,0,0,0,0,0},{1,1,1,4,2,0,0,0,0,0,0,0,0},{1,1,1,4,3,0,0,0,0,0,0,0,0},//13 {1,1,2,1,3,0,0,0,0,0,0,0,0},{1,1,2,1,4,0,0,0,0,0,0,0,0},{1,1,2,3,1,0,0,0,0,0,0,0,0},{1,1,4,3,1,0,0,0,0,0,0,0,0},{1,1,1,3,3,0,0,0,0,0,0,0,0},{1,1,2,4,2,0,0,0,0,0,0,0,0},{1,2,2,1,2,0,0,0,0,0,0,0,0},{1,1,2,3,3,0,0,0,0,0,0,0,0},//14 {1,1,3,2,2,0,0,0,0,0,0,0,0},{1,1,3,3,2,0,0,0,0,0,0,0,0},{1,2,3,1,3,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0} //15 }, { //File 1 {1,1,2,3,1,2,0,0,0,0,0,0,0},{1,2,1,2,1,0,0,0,0,0,0,0,0},{1,4,2,3,0,0,0,0,0,0,0,0,0},{5,0,0,0,0,0,0,0,0,0,0,0,0},{1,4,1,4,0,0,0,0,0,0,0,0,0},{1,2,1,2,1,2,0,0,0,0,0,0,0},{2,5,0,0,0,0,0,0,0,0,0,0,0},{1,2,2,3,2,0,0,0,0,0,0,0,0},//0 {1,2,1,2,2,2,0,0,0,0,0,0,0},{1,1,1,2,2,2,1,0,0,0,0,0,0},{1,2,2,5,0,0,0,0,0,0,0,0,0},{1,2,2,1,2,2,0,0,0,0,0,0,0},{1,1,2,2,1,2,1,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},//1 {1,2,3,2,0,0,0,0,0,0,0,0,0},{1,2,4,2,0,0,0,0,0,0,0,0,0},{1,1,1,1,1,2,1,1,1,0,0,0,0},{1,1,1,2,3,1,0,0,0,0,0,0,0},{1,1,1,3,2,1,0,0,0,0,0,0,0},{1,1,1,3,1,2,0,0,0,0,0,0,0},{1,1,2,2,1,1,0,0,0,0,0,0,0},{1,1,1,4,1,1,0,0,0,0,0,0,0},//2 {1,1,2,2,3,1,0,0,0,0,0,0,0},{1,1,4,1,2,1,0,0,0,0,0,0,0},{1,1,1,4,1,2,0,0,0,0,0,0,0},{1,1,1,1,4,1,0,0,0,0,0,0,0},{1,1,1,2,2,2,0,0,0,0,0,0,0},{1,1,1,3,1,1,0,0,0,0,0,0,0},{1,1,1,3,3,1,0,0,0,0,0,0,0},{1,1,1,1,3,2,0,0,0,0,0,0,0},//3 {1,1,2,1,2,2,0,0,0,0,0,0,0},{1,1,2,1,1,3,0,0,0,0,0,0,0},{1,1,1,3,1,1,1,0,0,0,0,0,0},{2,4,2,0,0,0,0,0,0,0,0,0,0},{1,2,3,1,2,0,0,0,0,0,0,0,0},{1,5,1,0,0,0,0,0,0,0,0,0,0},{1,1,2,1,1,2,2,0,0,0,0,0,0},{1,1,1,1,1,1,1,0,0,0,0,0,0},//4 {1,1,1,1,1,1,2,0,0,0,0,0,0},{1,1,1,1,1,1,4,0,0,0,0,0,0},{1,1,1,1,1,2,1,0,0,0,0,0,0},{1,1,1,1,1,4,1,0,0,0,0,0,0},{1,1,1,1,2,1,1,0,0,0,0,0,0},{1,1,1,1,4,1,1,0,0,0,0,0,0},{1,1,1,2,1,1,1,0,0,0,0,0,0},{1,1,1,1,1,1,3,0,0,0,0,0,0},//5 {1,1,1,1,1,3,1,0,0,0,0,0,0},{1,1,1,1,1,2,2,0,0,0,0,0,0},{1,1,1,1,1,2,3,0,0,0,0,0,0},{1,1,1,1,1,3,2,0,0,0,0,0,0},{1,1,1,1,2,1,2,0,0,0,0,0,0},{1,1,1,1,2,1,3,0,0,0,0,0,0},{1,1,1,1,2,3,1,0,0,0,0,0,0},{1,1,1,1,3,1,2,0,0,0,0,0,0},//6 {1,1,1,1,3,2,1,0,0,0,0,0,0},{1,1,1,2,1,1,2,0,0,0,0,0,0},{1,1,1,2,1,1,3,0,0,0,0,0,0},{1,1,1,2,1,2,1,0,0,0,0,0,0},{1,1,1,2,1,3,1,0,0,0,0,0,0},{1,1,1,3,2,1,1,0,0,0,0,0,0},{1,1,2,1,1,2,1,0,0,0,0,0,0},{1,1,3,1,1,2,1,0,0,0,0,0,0},//7 {1,1,1,1,2,2,2,0,0,0,0,0,0},{1,1,1,1,0,0,0,0,0,0,0,0,0},{1,1,1,2,0,0,0,0,0,0,0,0,0},{1,1,1,7,0,0,0,0,0,0,0,0,0},{1,1,2,1,0,0,0,0,0,0,0,0,0},{1,1,7,1,0,0,0,0,0,0,0,0,0},{1,1,1,3,0,0,0,0,0,0,0,0,0},{1,1,1,4,0,0,0,0,0,0,0,0,0},//8 {1,1,1,5,0,0,0,0,0,0,0,0,0},{1,1,5,1,0,0,0,0,0,0,0,0,0},{1,1,2,2,0,0,0,0,0,0,0,0,0},{1,1,2,6,0,0,0,0,0,0,0,0,0},{1,1,6,2,0,0,0,0,0,0,0,0,0},{1,2,1,2,0,0,0,0,0,0,0,0,0},{1,2,1,6,0,0,0,0,0,0,0,0,0},{1,2,2,1,0,0,0,0,0,0,0,0,0},//9 {1,1,2,3,0,0,0,0,0,0,0,0,0},{1,1,2,5,0,0,0,0,0,0,0,0,0},{1,1,3,2,0,0,0,0,0,0,0,0,0},{1,1,3,5,0,0,0,0,0,0,0,0,0},{1,2,1,3,0,0,0,0,0,0,0,0,0},{1,1,5,2,0,0,0,0,0,0,0,0,0},{1,1,5,3,0,0,0,0,0,0,0,0,0},{1,2,1,5,0,0,0,0,0,0,0,0,0},//10 {1,2,3,1,0,0,0,0,0,0,0,0,0},{1,2,5,1,0,0,0,0,0,0,0,0,0},{1,3,2,1,0,0,0,0,0,0,0,0,0},{1,1,2,4,0,0,0,0,0,0,0,0,0},{1,1,4,4,0,0,0,0,0,0,0,0,0},{1,1,3,3,0,0,0,0,0,0,0,0,0},{1,1,3,4,0,0,0,0,0,0,0,0,0},{1,3,1,4,0,0,0,0,0,0,0,0,0},//11 {1,2,2,4,0,0,0,0,0,0,0,0,0},{1,3,4,2,0,0,0,0,0,0,0,0,0},{2,2,2,2,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},//12 {1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},//13 {1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},//14 {1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0},{1,0,0,0,0,0,0,0,0,0,0,0,0} //15 }, { //File 2 {1,1,2,3,1,1,0,0,0,0,0,0,0},{3,5,0,0,0,0,0,0,0,0,0,0,0},{3,4,0,0,0,0,0,0,0,0,0,0,0},{1,2,1,2,1,3,0,0,0,0,0,0,0},{1,1,1,2,1,1,2,1,0,0,0,0,0},{1,2,1,3,3,0,0,0,0,0,0,0,0},{1,1,1,2,2,1,1,0,0,0,0,0,0},{2,3,4,0,0,0,0,0,0,0,0,0,0},//0 {1,2,3,2,1,0,0,0,0,0,0,0,0},{1,1,4,1,2,0,0,0,0,0,0,0,0},{1,3,2,3,0,0,0,0,0,0,0,0,0},{1,3,2,4,0,0,0,0,0,0,0,0,0},{1,3,1,5,0,0,0,0,0,0,0,0,0},{1,1,4,1,3,0,0,0,0,0,0,0,0},{1,1,1,5,2,0,0,0,0,0,0,0,0},{1,1,3,1,2,0,0,0,0,0,0,0,0},//1 {1,1,4,2,0,0,0,0,0,0,0,0,0},{1,2,1,2,3,0,0,0,0,0,0,0,0},{1,1,2,3,2,0,0,0,0,0,0,0,0},{1,2,2,1,4,0,0,0,0,0,0,0,0},{2,3,3,0,0,0,0,0,0,0,0,0,0},{1,1,2,2,2,0,0,0,0,0,0,0,0},{1,1,4,2,2,0,0,0,0,0,0,0,0},{1,1,2,2,4,0,0,0,0,0,0,0,0},//2 {1,1,4,3,0,0,0,0,0,0,0,0,0},{1,1,1,6,0,0,0,0,0,0,0,0,0},{1,2,2,2,0,0,0,0,0,0,0,0,0},{1,2,5,2,0,0,0,0,0,0,0,0,0},{1,1,3,1,3,0,0,0,0,0,0,0,0},{1,2,2,3,1,0,0,0,0,0,0,0,0},{1,4,3,0,0,0,0,0,0,0,0,0,0},{2,4,3,0,0,0,0,0,0,0,0,0,0},//3 {1,1,2,4,1,0,0,0,0,0,0,0,0},{1,4,3,2,0,0,0,0,0,0,0,0,0},{1,3,3,3,0,0,0,0,0,0,0,0,0},{1,2,2,3,0,0,0,0,0,0,0,0,0},{1,1,3,2,1,0,0,0,0,0,0,0,0},{1,1,3,1,0,0,0,0,0,0,0,0,0},{1,1,1,2,1,2,2,0,0,0,0,0,0},{1,1,4,1,0,0,0,0,0,0,0,0,0},//4 {1,3,2,2,0,0,0,0,0,0,0,0,0},{1,4,2,0,0,0,0,0,0,0,0,0,0},{1,5,0,0,0,0,0,0,0,0,0,0,0},{1,1,4,2,1,0,0,0,0,0,0,0,0},{1,2,1,3,1,0,0,0,0,0,0,0,0},{1,2,3,3,0,0,0,0,0,0,0,0,0},{1,2,1,4,1,0,0,0,0,0,0,0,0},{1,5,2,2,0,0,0,0,0,0,0,0,0},//5 {1,1,6,1,0,0,0,0,0,0,0,0,0},{1,1,1,2,2,1,0,0,0,0,0,0,0},{1,1,1,1,3,1,1,0,0,0,0,0,0},{1,3,3,2,0,0,0,0,0,0,0,0,0},{1,2,3,4,0,0,0,0,0,0,0,0,0},{1,3,3,1,0,0,0,0,0,0,0,0,0},{1,2,4,3,0,0,0,0,0,0,0,0,0},{1,1,3,4,1,0,0,0,0,0,0,0,0},//6 {1,1,1,1,1,1,1,2,1,0,0,0,0},{1,2,1,2,2,0,0,0,0,0,0,0,0},{1,1,1,2,3,2,0,0,0,0,0,0,0},{1,1,3,3,1,0,0,0,0,0,0,0,0},{1,2,4,0,0,0,0,0,0,0,0,0,0},{1,3,1,3,2,0,0,0,0,0,0,0,0},{1,1,3,1,4,0,0,0,0,0,0,0,0},{1,1,1,4,1,0,0,0,0,0,0,0,0},//7 {1,1,2,2,3,0,0,0,0,0,0,0,0},{1,2,1,4,0,0,0,0,0,0,0,0,0},{1,2,1,2,4,0,0,0,0,0,0,0,0},{1,1,1,1,2,1,1,1,1,0,0,0,0},{1,3,1,3,0,0,0,0,0,0,0,0,0},{1,1,1,0,0,0,0,0,0,0,0,0,0},{1,2,1,3,2,0,0,0,0,0,0,0,0},{1,3,2,2,2,0,0,0,0,0,0,0,0},//8 {1,1,2,1,1,2,1,1,0,0,0,0,0},{1,1,2,0,0,0,0,0,0,0,0,0,0},{1,1,8,0,0,0,0,0,0,0,0,0,0},{1,2,1,0,0,0,0,0,0,0,0,0,0},{1,1,3,0,0,0,0,0,0,0,0,0,0},{1,1,7,0,0,0,0,0,0,0,0,0,0},{1,3,1,0,0,0,0,0,0,0,0,0,0},{1,1,4,0,0,0,0,0,0,0,0,0,0},//9 {1,1,6,0,0,0,0,0,0,0,0,0,0},{1,4,1,0,0,0,0,0,0,0,0,0,0},{1,1,5,0,0,0,0,0,0,0,0,0,0},{1,2,2,0,0,0,0,0,0,0,0,0,0},{1,2,7,0,0,0,0,0,0,0,0,0,0},{1,2,3,0,0,0,0,0,0,0,0,0,0},{1,2,6,0,0,0,0,0,0,0,0,0,0},{1,3,2,0,0,0,0,0,0,0,0,0,0},//10 {1,3,6,0,0,0,0,0,0,0,0,0,0},{1,6,2,0,0,0,0,0,0,0,0,0,0},{1,6,3,0,0,0,0,0,0,0,0,0,0},{1,2,5,0,0,0,0,0,0,0,0,0,0},{1,4,5,0,0,0,0,0,0,0,0,0,0},{1,5,2,0,0,0,0,0,0,0,0,0,0},{1,5,4,0,0,0,0,0,0,0,0,0,0},{1,3,3,0,0,0,0,0,0,0,0,0,0},//11 {1,3,5,0,0,0,0,0,0,0,0,0,0},{1,5,3,0,0,0,0,0,0,0,0,0,0},{1,3,4,0,0,0,0,0,0,0,0,0,0},{1,4,4,0,0,0,0,0,0,0,0,0,0},{2,2,2,0,0,0,0,0,0,0,0,0,0},{2,2,4,0,0,0,0,0,0,0,0,0,0},{6,0,0,0,0,0,0,0,0,0,0,0,0},{1,3,2,1,3,0,0,0,0,0,0,0,0},//12 {1,1,0,0,0,0,0,0,0,0,0,0,0},{1,2,0,0,0,0,0,0,0,0,0,0,0},{1,9,0,0,0,0,0,0,0,0,0,0,0},{1,3,0,0,0,0,0,0,0,0,0,0,0},{1,8,0,0,0,0,0,0,0,0,0,0,0},{1,4,0,0,0,0,0,0,0,0,0,0,0},{1,7,0,0,0,0,0,0,0,0,0,0,0},{1,6,0,0,0,0,0,0,0,0,0,0,0},//13 {2,2,0,0,0,0,0,0,0,0,0,0,0},{2,3,0,0,0,0,0,0,0,0,0,0,0},{2,4,0,0,0,0,0,0,0,0,0,0,0},{2,6,0,0,0,0,0,0,0,0,0,0,0},{3,3,0,0,0,0,0,0,0,0,0,0,0},{5,4,0,0,0,0,0,0,0,0,0,0,0},{1,1,4,1,1,0,0,0,0,0,0,0,0},{1,1,2,2,1,3,0,0,0,0,0,0,0},//14 {1,1,2,2,1,1,2,0,0,0,0,0,0},{1,1,1,3,1,1,2,0,0,0,0,0,0},{1,1,1,3,2,2,0,0,0,0,0,0,0},{2,0,0,0,0,0,0,0,0,0,0,0,0},{2,2,5,0,0,0,0,0,0,0,0,0,0},{2,7,0,0,0,0,0,0,0,0,0,0,0},{2,2,2,2,2,0,0,0,0,0,0,0,0},{1,1,1,1,3,1,1,1,0,0,0,0,0} //15 } // End of File 2
- 1 reply
- 2
hi is it possible to use 2x 2x40 lcd in combination with more encoders under it? can it be done with a custom hardware config file or is more asm code to do? && can the engine switched on the fly? or do i have to upload new code before having a lead bass drum or poly engine? thx 4 tips.
SeqV4 Mongobox Stopmotion built (+mjsigl jamsession audio)
Phatline posted a topic in Songs & Sounds
- seqv4
- stop motion
- (and 4 more)
dont matter, the dout or din - line is looped thru the boards... but i think its better to put the din boards at the beginning of the chain, because they are more sensibel - they are sensing...
- 2 replies
- mbph core v3
- din
(and 3 more)
Tagged with:
MIOS32_BOARD_Jx_PinGet (x) returns 0 (when set 2 ANalog)
Phatline replied to Phatline's topic in MIOS programming (C)
sound like a plan! thx. -
i just read the documentation; http://www.midibox.org/mios32/manual/group___m_i_o_s32___b_o_a_r_d.html#gae4a1b2afe98fdf86a5b20216fe4c2bbd for me it seemed that it should work... When using AIN-Driver, the AINs are read in background. can i then manually command to start a read out? (maybe in combination with "#define MIOS32_DONT_SERVICE_AIN 1"?) background to this quest: i have 4 IR Diodes, and one IR Receiver (my AIN) i have to cycle ON/OFF-the 4IR Diodes... So i have to Activate a Diode, read the state, deactivate it, then the next Diode, read the AIN State, its importend to do this in perfect timing. (in order to calculate a XYZ-Read out of my hand) -
hi i tested the tutorial now, and set as Digital Input- as the Tutorial is, it works. it sends midi notes when moving the potentiometers. but when changing the initalitaion to void APP_Init(void) { // initialize all LEDs MIOS32_BOARD_LED_Init(0xffffffff); // initialize all pins of J5A, J5B and J5C as inputs with internal Pull-Up int pin; for(pin=0; pin<12; ++pin) MIOS32_BOARD_J5_PinInit(pin, MIOS32_BOARD_PIN_MODE_ANALOG); } and let the rest of the tutorial untouched, it doesnt send anything when moving any of the 8 potentiometers. the Analog mode doesnt work - or what do i miss here? -
no, my code on this point is right: the word "static" initialize a variable only @ first run, after that - the init-value "0" is ignored. this is really handy
