GM5: Least-cost USB-MIDI Interface Chip for 4.50 EUR
  • Replies 732
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Got mine and installed it in my MIDIbox sneaquencer: http://sneak-thief.com/sneakyseq.html :)
After searching for a nice case-mountable USB-jack, I settled on this reversible Neutrik USB Type-A / Type-B one:
Re. Driver: I used the v1.07 of the windows 32 bit driver and all the ports were names were *so* long ("Ploytec USB Midi blah blah" or something) that the port numbers at the end of the name wouldn't show up in the Midi-Ox dialogue boxes ...and I couldn't rename them using the .inf file! I rolled back to v1.06 and everything worked perfect.
Just Phil - greetings to Edmonchuck! Lived there for the first 27 years of my life.
I gave up, as i butchered 3/4 of my gm5 chips trying to solder them to the boards.
i may have 'big fingers' but it's definitely not THAT easy :(
Any chance that ploytech could solder the chips to the boards directly ?
How did you "butcher" them? Chances are - they're not really dead. They can take quite a lot of abuse - I deliberately tried to kill one by soldering and desoldering it three times, trying different techniques, and it still works like a charm. You got some pics? Maybe we can help you find a way to fix them ;)
nILS will tell you that i actually devastated a GM5
It's a long story but needless to say i put so much heat through it with the iron it should have been liquid
I am not kidding now i was pulling my hair out after hours trying to get it to solder (Involvinga broken iron and everything, a true nightmare)
However even after all these hours of frying the chip i eventually used a different iron
And got it to take and the thing still works perfectly now
Just don't give up on these things
A technique that i use now (And im sure people will laugh at this)
Tin the pads on the board
Tape the SMD in place using a piece of insulation tape then heat up a leg until you get a tack
Then just solder it best you can and don't worry about excess solder
Then use wick to clean it up and make sure there are no shorts
Hope this helps but all i want to do here is stress that these are doable even by a complete knuckle like me
Flexi
Oh PS i have done a few more since and each one gets easier as you get more confident ;)
I thought the chips were pre-tinned such that, at least if you're soldering it down for the first time, you really don't need to use any more solder?
Either way, from what I understand, taping the chip down is a very common, and useful, procedure :)
Shipped 2009-10-21:
joeribl
jbaldwinroberts
Vitaly
Shipped today:
roman01
einwang
flip
nsunier
Fine :)
And here the next ones:
tomcody
vcfool
Simca
Streusalz
Dr_Nick
I have one -spare- GM5 with the Chip for "new year giveaway", first come first gets. only thing you need to pay is the postage.
This is in true spirit of DIY and 2010 :-)
I followed the recommondations on tk_gm5_bulkorder and sent TK the following mail via forum mail:
GM5: 1
PCB: 1
Gerhard Zxxxx
Wxxxxxxxstr. 112
90xxx Nürnberg
Deutschland
PayPal: no
MyName@mymail.com
in return I've got:
Mail delivery failed: returning message to sender
From: Mail Delivery System <Mailer-Daemon@server.twin-x.com>
To: hxxx.cxxx@web.de
Please note that MIDIbox Forum has no control over the
contents of this message.
Now I'd like to know what I've done wrong?
Gerhard
Strange - does it work when you are sending the mail via the messenger?
I just tried it, please have a look if it arrived.
Thanks
Gerhard
