ilmenator
Frequent Writer
    2,305
    37
  1. Do you have the datasheets of the two devices to compare?
  2. The port names refer to the MBHP LPC17 Core board. You seem to be using some kind of protoboard, so I am pretty confident your J9 is not our J9. You will have to check the schematics of your board and the LPC17 core board and compare - you want to know which pins on your board connect to the relevant pins of the processor itself. Good luck!
  3. I have just ordered my panel, it will be in my hands around Oct 14 or so. You could visit www.ponoko.com, they have a hub in New Zealand, this is where Wilba's SammichSID and -FM cases are made.
  4. Also, I did not see any info on the switching frequency of the PSU at Reichelt. The one here has a high-enough switching frequency and is, as Shuriken stated, known to be good. The Reichelt one could be good, too, but it has not been tested.
  5. Und dann noch eine eigene Taste pro Reiter und das Touchpanel kann wieder in den Schrank!
  6. Yes, this is the place where you want to start experimenting. See what encoder mode is most suitable for your model of encoder.
  7. For such small cases you could always replace the metal with acrylic panels and have them lasered at Ponoko.
  8. I will take two - thanks for making this happen! edit: no Molex connectors for me!
  9. But it still has to be 19", i.e. go into a rack?
  10. Have a look at how this is done in MBSEQ V4. There you have to explicitly enable PC access to the card in the menu. Once this is done, the SD card is visible as a USB storage device to the PC.
  11. Da das (Graphitbeschichtung) kein Standard in der Platinenfertigung ist wird es mit Sicherheit so teuer, dass du mit einer anderen Lösung besser bedient bist: absägen oder eine ganz andere Tastatur besorgen.
  12. That should actually not be a big deal. If in doubt, place a dust cover over the unit whenever it is not used and you're as good as with these plastic things.
  13. Oh yes, the EPIC video... :thumbsup: I wonder how long he tried until he got the soundtrack right!
  14. Super! Dann sag doch mal welche Gesamtkabellaenge du jetzt hast, falls mal jemand in diesen Thread schaut und genau das wissen will!
  15. Schoenes Projekt! Hast du keinen MIDI-Out vorgesehen? Wie werden dann Sounds und Einstellungen uebertragen und gespeichert? Gruesse, ilmenator
  16. First swap the displays around to make sure it's not the displays' fault. Then I would look at/continuity test the PCB for obvious mistakes. I assume you are using an official display driver? Check the Readme how many displays are actually supported.
  17. It's probably the same stuff responsible for the questionnaire you are supposed to fill in when you arrive in their country...
  18. To get back on topic: the card reader itself is ok, I have ordered one myself a few weeks ago. But mounting it in a case is a little difficult, as the two (only!) mounting holes are rather small and located very close to the DIL connector. Also, the card reader is only soldered in the back. The front (the side on which the card is inserted) can be lifted up from the PCB, so a little soldering is required to fix this.
  19. Yeah, but why three different postings, all in the same forum section?
  20. He, you are right! I looked in the wrong quote... sorry! Panel mount is of course possible, but then again I do not see the point in reversing one of the PCBs?
  21. As the extension .hex suggests, this is NOT a text file. Text files will not work. Hence, if you copy its content into a text file and only change its extension to .hex, it will remain a text file and continue to not work. Try the "Save link as..." option in your browser, from the page linking to the file.
  22. No, he said panelmount when he was referring to the USB connectors. And yes, it would really be so bad, because you never knew for sure which way around to plug the connector unless you tried. Especially annoying when making new connections in a rack, when the backplane of the device is most probably sitting considerably deeper buried into the rack than that of all other gear.
  23. Sounds a LOT like Emagic's AMT-8 :whistle: .
  24. So that half of the connectors are sitting upside down? Bad idea from a usability point of view.
  25. Short answer: NO.
