Shuriken
Frequent Writer
    973
    11
Everything posted by Shuriken
  1. Indeed, whoohoo
  2. Yeah, it looks like something an admin must fix.
  3. Geriztul
  4. Since a couple of days it seems that the View New Content button is no longer working. I get an error: What's going on?
  5. Isn't the PCM1702 meant to be an Audio DAC?
  6. Damaging the PIC should not be possible through the MIDI IN. The 6N13x Optocoupler is there to prevent this scenario. Inside the IC there is an optical connection, this way there is no direct electrical connection.
  7. No, there is no problem if you leave it.
  8. You can buy the pcb at: SmashTV Mikes Midishop For parts you can try reichelt, musikding, banzaimusic. The only tricky part is the OPL3 chipset. You can try on ebay. Maybe someone has a trusted source?
  9. Nice find. Curious what the sample quality is. But it's probably not that great with just 4Mbit of ROM. Love to hear a demo when you get it :wink:
  10. There was a buyorder a couple of years ago. Not sure where to get one now.
  11. As a general rule of thumb; when a component is broken, it's better to use the wire cutter method as Peter described. It's much easier that way to get components out without damaging the pcb.
  12. Look at the example on the wiki: http://www.ucapps.de/midibox_sid/mbsid_aout_interconnections.pdf The correct names are there, just use J19 in case of the LPC17.
  13. My suggestion would be: check the interconnection between baseboard and CS with multimeter check correct placing of resistor networks check soldering of the 74HC165 sockets
  14. This was bound to happen after all the metal Shruthi enclosures :wink: Looks good man!
  15. Great you found a good switching psu solution. The enclosure with the frontpanel looks nice.
  16. I have a MB FM and have been pondering about the same thing. It should be possible to make a sammich interface which fits an 1U panel.
  17. Apparently somebody started with the SID Emu:http://www.xcore.com/projects/sid-emulator-startkit
  18. Enjoyed your song and the copter footage :w00t: Offtopic: I did buy a Mobius hd. So far only used it for some sky footage :wink:
  19. Nice eptheca. Love to hear a demo with the filters. As you may remember i have one filter board here too :wink:
  20. I had a similar problem. Updated the bootloader on my Seq4L after that no ports were available in MIOS Studio. I fixed it by removing the usb midi driver completely.
  21. The LPC17 Documentation says: So either J4A or if that one in use then you can use J4B.
  22. You could do that. Beware that it runs under CygWin. So you still have to do linux commands. Might be cheaper and more flexible to make a virtual machine with Ubuntu 12.04. There are a lot of tutorials available.
  23. You should be able to build MIOS Studio for Pi. Not sure about the Midi Bridge. But there seems to be a sourcecode for linux.
  24. I am sure that someone is willing to help. But it might be handy to reveal your location :wink:
  25. I found the code googling a bit. Take me a bit of effort to get it working. I think there is a plugin for IPB so that it is possible todo it the easy way.
