Hola,
Would you think, that it would be feasible to create a new LPC-based BLM (16x16+x) communicating with the SEQ via ethernet (using the onboard network adapter of the LPC1769)?
And if so, would it be possible to "stack" this unit?
I´d love the idea to have a compact and cheap 16x16+x BLM unit, which could be extended over time with up to three peers to get a large 64x16 BLM and feel like Jean Luc Picard :-).
Of course, then every unit needs to be as inexpensive as possible - e.g. by using cheap duo-color leds and tactile-switches with integrated buttons (5x5mm), just like the ones in the photo attached - cost per switch: 5 cents, cost per LED 8-10 cents (I had only single-color SMD LEDs available for illustration at the moment).
As these elements are SMD, they will be quicker to solder than their through-hole counterparts.
The completed BLMs would also be nicely compact, less than 20 centimeters wide for a 16x16+x BLM.
The shown switches are very nice, have a "soft feeling" and the button distance of ca 1cm (5mm switch button cap, 5mm space) should be good for quick changes in the pattern or "live playing".
If a nice PCB color was chosen, we would not even need a frontpanel (which reduces costs even more).
The LPC would be carried as a "shield" at the top of the PCB - these "Mini-BLMs" should be stackable sideways with the possibility to omit the leftmost "+x" column of buttons and LEDs while soldering, as only the leftmost unit needs those.
There would only be an ethernet port and a power connector (or even only power-over-ethernet, the adapters have become very cheap).
Thanks for your feedback!
Greets,
Peter
