1,285 -
72
Everything posted by Phatline
my first Art-Music-Video, the story goes round the hamsterwheel it sadness and the escaping off it... there are also english subtitles! and also german subtitles (Because i sing in austrian dialect)
- 2 replies
- 1
- crimic
- hamsterrad
(and 2 more)
Tagged with:
From the album: C - Stuff
phatlines built - made for User C4M - have fun. -
i have lost 2 pieces off this Black Buttons (dimensions: 12x6mm - height 11mm) does anybody have 2 of them -coming from austria or france (i built this mongbox for a france man...) or does anybody know where to get them from --- THX - mike.
I sell my used BLM16x16+X. The Orginal BLM16+16+X has a 8Bit microcontroller, this one has some modifications: * 32Bit Core Module (Micrcontroller) * 2x2 Midi IO * a bootloader switch, if you bricked somehow the device, with this normally you get it to live.... * and a expansion port on the front (AIN, DIN), (which you maybe never need, except your are a programmer...) * I soldered yesterday new Faders, so they are brandnew, they are connected to a Serial AIN Board, so they work with 5V! (normally Faders direct connected to a 32bit MCU needs 3.3V, so less resolution) you could mount 12 more faders or pots into it, or via expansion port (DIY...) * it is 5V USB-Powered, and can be used as USB-Midiinterface, as well there is a sysex protocoll to fast transfair button-led status between a Max-Msp Patch/Ableton live and so on... but for that you have to DIY again * Theoretical it also can be powered from the SEQV4, but for that you have to carefulle check the 8-Pin DIN-Socket on the backside off the Device - this holds 2 extra Midi ins 1 Midiout and +-5V --- but i dont know if it wired correctly - you may have to check that yourself (DIY!) I fully cleaned and checked it yesterday (i completely disasaambled and assambled it) leds are: blue-green-cyan --- and all are working Price: 800 here more detailed Calculation: (without the expansioport, additional midi IO) so you see where the cost is coming from... - i would sell it on sequencer.de - and i think i would find a buyer there - but i cant post there (not enough posts or +-points) -maybe someone can give them a wink...
yes, 5v to pa0 and then reconnect usb and watch what mios studio says...it should day "bootloader" as usb port instead mios32, in this mode upload s nother app...
crimic-live-at-JET-Benefiz-Concert-2019-06-07
Phatline replied to Phatline's topic in Songs & Sounds
i mixed our sound on stage with our own mixer (like always) with the crappiest crackiest paper monitors i ever heard (you may can send a voice on it, but bass? kick? a stereo summ of EDM > no way!) i sent the stereo-summ to the "sound manager" the sound manager was sent here from church during his "social task year"... he hasent any clue, nor interest, he was sitting there doing "smart"-phone - no it was no "mixer" app ;) the sound manager - managed to get the thinnest silence sound on the floor ever.. and when he heard feedback from our mics, he quickley reduced our Stereo Summ on Main PA > well thank you - not! i drunk 2 beers...then it turned out that i had to build up the main pa, and helped other bands - because the sound manager havent any glue --- what i learnt --- always - always -always take your own Monitors with us, and sent the stereo-sum (if possible) directley to main PA --- hopefully my bandmate learnt this too -because i was the one that wantet to take the monitors with us in first feeling... -
to cancel out a problem with your code: force your discoboard into "bootloader mode": http://wiki.midibox.org/doku.php?id=home:mbhp:module:bootloader-switch then try to upload a simple test program.
a outtake from our Benefiz-Concert - for a local youth-centrum... https://youtu.be/bgcucZcvW2Q
MIOS32 - Compile error after fresh install of the toolchain
Phatline replied to jujule's topic in MIOS programming (C)
do you compile a standard app? or some own programmed? (> you get that message by every app you want to compile?) (i also use ubuntu - and for me its always pain in the ass - to get it running > all the librarys you have to install... luckely i dont have to fresh install my OS only once a few years...) -
what would your perfect control surface look like and do?
Phatline replied to madbutnotmad's topic in MIDIbox NG
control sourface for what? DAW? Synth? Record-Session? Ableton? ... it depends... For in Depth Edit: Endless-Encoders with "end-break" + 2toRGB Color Ledrings with at leas 16 LEDs + LCD above it to show the parameter-name + CC-Automation + CC-Patch-Storage. or Normal Mouse and or Touchscreen if its for example Ableton For Live Play: (all 8 or so most used Parameters for a gig) Potis and Faders for Liveact-Action well arangent and unique in feel look and size ---so you can drive it blind... i found out that there are only a few importent Parameters, to mouch of Parameters, make it to complicated... -
i had a fiew people that wanted me to make one... but when i wrote them a realistic price the run away.... so i learned....if you send me all the parts i can assembly and solder the project for you...(sourcing parts isnt a big problem here with mouser parts list anyway - the project is really good documentaded) to shift hundrets of teuros from bank to bank is notca very good idea... i take 20€/h and can give you for that time a honorar note for it (as a free artist for a other artist for building a music device) thats the same ammount i charge for drawings and shooting photos or other arts. best mike.
EDIT: ui ui.... @admins > wrong forum-section: could someone please move this to the BLM-Section... thanks Hi i took some time to calculate the total costs from all parts, inclusive build time, from the last BLM16x16+X Variant. i have done this because someone offered me 300€ for a working - not used- unit (excl Case), and i thougt its a bit too less , so a calculated...: here is what i got, for the whole unit: 16x16+X Cost what from pieces price Forreign EUR 4x4 softbuttons adafruit 18 $4,46 $80,28 € 71,45 DHL EXPRESS WORLDWIDE adafruit 1 $29,67 $29,67 € 26,41 PREPAID DUTIES AND TAXES adafruit 1 $24,37 $24,37 € 21,69 electronic components mouser 1 € 253,00 € 253,00 € 253,00 523-T3507-000 8pole Din-connector mouser 1 € 8,72 € 8,72 € 8,72 spacer formular 1 € 49,43 € 49,43 € 49,43 shipping formular 1 € 12,50 € 12,50 € 12,50 Main BLM PCB midibox 1 $75,00 $75,00 € 66,75 shipping midibox 1 $12,00 $12,00 € 10,68 case midibox 1 $270,00 $270,00 € 240,30 built time phatline 15 $20,00 $300,00 € 267,00 Shipping the ready thing 2 you country? 1 € 20,00 € 20,00 € 20,00 STM32-Variant Core STM32F407G-DISC1 Mouser(1x) 0 € 17 € 0,00 € 0,00 core pcb smashtv(1x) 0 € 10 € 0,00 € 0,00 core parts smashtv(1x) 0 € 13 € 0,00 € 0,00 midi io pcb smashtv(1x) 0 € 7 € 0,00 € 0,00 midi io parts smashtv(1x) 0 € 7 € 0,00 € 0,00 built time phatline(1x) 0 € 20 € 0,00 € 0,00 Core-8-Variant ca. midibox(1x) 1 $25,00 $25,00 € 22,25 SUMMED € 1.070,17 Its round 800 if you DIY Soldering and Assamble the whole device its round 550 if you CNC the case yourself ...You can play arround by download the open-office-document here: 16x16 costs.ods however i endet up that 300€ its too less... maybe that helps to get some overview what comes to you when you want to built your own the next run...
- 13 replies
- calculation
- cost
(and 2 more)
Tagged with:
can you upload your own dsp code there? see nothing on there site...
nope but but looks good. will have to search a soundcard for pi with lowest latency and best sound abd normal price... since the project is played and triggered live... ans alao how to use midibix in this envieonment... midi ttl i guess
... i was searching for a cheap soundmodule... and came back to this... and its midi cc-able..:http://serdaco.com/downloads/X2/X2_Documentation/X2_5504_SPECIAL_MIDISPECS.PDF ok there is this *.dxb [dreamsoundbank-format] which is a single binary file which, what seems somewhat closed (except you have +€650 for a editor), so there are no user-patches possible > except you have the money... but mostley as artist you have the art and time and not the money... so one comes the nothing other... and since 2016 there was no grow in his soundbanks (of course!!!) you can download 3 of them. info from 2016... dont know if there is anynews: so whats the deal with "dream"? I dont have a good feeling when looking on this lack of user-bank... maybe this is more a way to go...https://www.tindie.com/products/monkeeeys/midi-sound-module/ if you just want to play sf2 files... (i know this here is for soundcards... but in fact the dream pcb could be used in a midibox environment to... so..)
youtube video a outtake from our concert in the ars-electronica-center "skyloft", its smooth, beautiful music, we paint art like: vernissage, motion-picture, book-presentation and lyric.... i heavyly used my midibox triggermatrix for the beats and sounds.... we have also more 4the floor songs... this was more lounge. have fun...
after founding our label in order to make our own isrc codes, and programming our bandsite www.crimic.at, and after endless jamsessions,after adding a songmode to my triggermatrix, after months of video editing having a music video... we want release our songs... but which distributor (that can do beatport too... and the ni stems format)?youtube is full with us gb or nl distributors but i want a distributor on the european mainland... i found dig.dis they ca do stems.mp4 any expierence with them or others? thx for any info - mike
EDIT: SOLVED > i replace Q11 > now all ok following failure: (all 2x16x16 leds are software side activated)
well, problem-solution: problem: the providet file "MIOS_Studio" is marked as Type "gemeinsame Bibliothek", while "mios_msi" (see screenswhot filebrowser) is marked as Type "Programm", "Programm" is executable with double click, while "Gemeinsame Bibliothek" is not. --- booth "MIOS_Studio" (which i got from ucapps) and "mios_msi" (Built from src on my machine) are marked as "als Programm ausführen" in the Preferencys. solution: create a program-folder, (in for example your home folder), and add its path to your environment variables (root/etc/environment) (PATH="/home/t/program" for example) put the MIOS_Studio File (from ucapps), into the program-folder then restart system. after that its still not possible to start Mios_Studio with double click, but you can start it with a console by Typing "MIOS_Studio" @Antichambre i like your Midnight theme...
@TK. my system: linux kernel 4.15.0-39 & also 4.18.016 , Linux mint mate 19 TARA i use MIOS Studio 2.4.6 ... it works (except the load hex button thing> the new 2-4-8 Mios Studio "rar" file you posted, i unpacked it, i checked that it is standart marked as "als program ausführen" in the file-browser settings... but double click or try to run it from console says "keine anwendung zum öffnen von Mios Studio gefunden" Do i have to install a Application first? which? thx.
LoopA V2 Introduction, Features & Support Thread
Phatline replied to Hawkeye's topic in MIDIbox User Projects
great! @ clip launch -
@lcsc.com: i have ordered there over the 20€-free area... ordered 200€ there, and paid +150€ taxes (austria, import tax, and zoll) - dont think that it is cheaper to import cheap china parts, instead of reichelt, mouser and co. the duty department of austria had a lot of questions- why i order 5000 parts - and didnt believe that it is non comercial...bla bla... ( it is not hard to get over 5000 parts, when the minimum order of a smd resistor is 50 100 or 200 pieces...) @ the end of the day i had massive bill --- so be aware. best mike
