ilmenator
Frequent Writer
    2,305
    37
  1. Julian, will you make the cut files available so that anybody with a CNC router can reproduce your frontpanels? Or would you rather people start from the frontpanel drawings that have been created in the past?
  2. Hi there, I am still working on this project, even though I haven't made any progress in the last year. I will probably continue to work on this after the summer. (Original) Wavestation cards and 01/W cards do not share the same wave format, so they cannot be adapted passively. They are completely different things. The WS SR uses the same format as the 01/W, though. Best, ilmenator
  3. What's the difference to your other SIL to DIL adapter on OSHPARK?
  4. Warum nimmst du nicht einfach Potis? Die werden von der MBNG Plattform genauso gut unterstützt wie Encoder. Grüße, ilmenator
  5. Nice one - let's hope for some more perfect summer days ;-)
  6. Please, let's not promote this kind of software. The programmers should be rewarded for their work. If you can't or don't want to afford the legitimate version, then go for free software instead. Heck, you even know there is one out there but "hate" it. I don't get it...
  7. For some sound demos you can just go over to the Mutable forum or search Youtube/Soundcloud. Plenty of demos of Ambika's capabilities there. Btw, this one houses 6x 4p cards, which are my favourites.
  8. Thanks Peter, not using Windows, I'm on a Mac (Yosemite v 10.10.5)... It's actually becoming a problem now: I am losing contact with the core, so that for example write operations to the SD card via the MIOS file browser will fail more often than not. This is very annoying as it keeps me from updating my NG configuration file and I can't continue the development of the TSFKAA MBNG setup.
  9. Hi, I am getting a message about a Timeout on port 0x21 quite regularly. I am not sure whether this actually is a problem (I haven't noticed any so far), but it bothers me and I'd like to know what this is. Here is an example of what I get in MIOS Studio: [267727.006] Init DHCP [267728.076] SD Card connected: [267728.796] Init DHCP [267728.797] [MBNG_FILE_C] Event Pool Number of Items: 396 [267728.797] [MBNG_FILE_C] Event Pool Allocation: 15867 of 65536 bytes (24%) [267728.801] [MBNG_FILE_L] DEFAULT.NGL hasn't been changed; reading labels from existing DEFAULT.BIN file. [267728.802] [MBNG_FILE_L] 15 labels found in /DEFAULT.BIN file [267728.803] [MBNG_FILE_S] snapshot #0 not stored in /DEFAULT.NGS yet [267749.392] [MIOS32_MIDI_Receive_Handler] Timeout on port 0x21 [267761.075] [MIOS32_MIDI_Receive_Handler] Timeout on port 0x21 [267768.483] [MIOS32_MIDI_Receive_Handler] Timeout on port 0x21 [267773.455] [FILE] Download of 39392 bytes in progress (0%) [267773.601] [FILE] Download of 39392 bytes in progress (25%) [267773.748] [FILE] Download of 39392 bytes in progress (51%) [267773.894] [FILE] Download of 39392 bytes in progress (77%) [267774.018] [FILE] Download of 39392 bytes finished. [267775.023] [MIOS32_MIDI_Receive_Handler] Timeout on port 0x21 [267800.299] set debug off [267800.301] Debug mode turned off [267801.305] [MIOS32_MIDI_Receive_Handler] Timeout on port 0x21 About two weeks ago, on the very same hardware, this Timeout message wasn't there. Any clues about what's going on here? Which port is 0x21?
  10. Sounds like floating RN common pins to me.
  11. Custom mainboard holds the usual stuff plus a complete DIO_MATRIX for keyboard scanning and parts of an AINSER64 (MCP3208 and the 595). From there, MUXA...MUXC as well as CH0...CH7 signals go to the frontpanel. MIDI I/Os are also on the mainboard.
  12. I was going to wait until the MIDIbox NG part of this was a little more mature, but you already spotted this over at the MI forum... So, this is a dedicated user interface / controller for the Mutabel Instruments Ambika analog synth, housed in a recycled synth case from the early 90's. The black PCBs are the six voice cards of the Ambika.
  13. Yes you can - simply click "edit" in your first post and then add [solved] to the title.
  14. If the buyer should need the BLM PCB, just drop me a PM... I have a few left from the last v2 batch.
  15. All the schematics are known, so you could easily design your own board layout.
  16. Mal ehrlich: wen interessieren Kratzer im Langloch? Da ist mir eine sichere Befestigung des Gerätes doch wichtiger...
  17. Not sure everyone can remember them (and understand that joke ), here is a pointer...
  18. That is just their business model, and it is perfectly understandable not to want to deal with consumer electronics issues. They are probably not a very large company and having to produce (and pay for the production) up-front could break their back, financially.
  19. Nylonunterlegscheiben, werden teilweise mit den Rackschrauben mitgeliefert, sind aber viel preiswerter und auch einzeln im Eisenwarenhandel zu finden.
  20. Sounds like a faulty resistor R8 or R10, or wrong value installed? Unpower the unit and measure resistance across R8 and then R10, both should read 220 Ohms. If that doesn't help, check resistance between M- on J6 of the MIDI IO board and pin PC12 on the STM32F4 board - this should also be 220 Ohms. These errors are a pain to find the root for, but it's better than having to search for an error that only shows every now and then...
  21. Have you tried earlier revs (i.e. before 092)? If you find that earlier versions work, then it sure is a software bug. I remember that some MIDI outs that are based on 3.3V are problematic with some MIDI gear that expects the "regular" 5V sources (this seems to be an issue even though MIDI is essentially a current loop). Maybe there are some tolerances between the Outs on your board that you hit?
  22. Here is the solution to the problem: by changing rows=8 into rows=10 the notes output for each of the 37 keys is correct, not just for the first 32.
  23. It will be available again - check back regularly in Tim's online shop as they tend to be out of stock rather sooner than later.
  24. That's right, file size is the problem here.
  25. No, the trouble was that the images were too large. I had to reduce them in size to get them below the maximum file size :-).
