ilmenator
Frequent Writer
    2,305
    37
  1. So how much flexibility is there for the BLM configuration (8x4, 4x4, 8x8) when it comes to assigning SEQ functionalities to the buttons? Do we need to recreate the original Wilba BLM in terms of schematic / PCB layout?
  2. I guess the main problem with multi-format is that you will have to accomodate the LEDs for your pads somewhere close to the center, which is where the Marquardts have one of two contact pins. I'd say don't bother, and if I ever feel so inclined I can always come up with a similar layout for "proper" switches (and then include multiple footprints as on the latest BLM 16x4 v2 version).
  3. Yes, all the TL1100 knockoffs are kind of crappy, and even the "original" E-Switch ones tend to go bad rather sooner than later. Rubber contacts are used in a number of Roland keyboards (for the actual piano keys), and yes I've had quite a few problems with these. ENIG plating might be a solution to the problem, but on top I'd rather press on something that gives me a more defined haptic feedback, so I never bothered too much with pads. I understand people go for the sexy look of these illuminated pads, and that's probably justification enough :-).
  4. I agree, plus I am not convinced about the durability and longevity of these pads / the contact system these use. I would prefer a solution with proper switches.
  5. Here are the dimensions for the mounting holes. Altitude is testing the prototype, I have PCBs available if anyone is interested.
  6. Are you still looking for one? I have one spare that I am selling, if needed as a complete kit including duo colour LEDs and stuff. PM me if interested. Vi snakkes ilmenator
  7. Dann kann man das so machen, korrekt.
  8. Guys, it's kind of kristal='s "privilege" (or obligation) to run the bulk order. Many years back we found out the hard way that it can be very bad if a manufacturer / industry supplier is flooded with small orders from unknown hobbyists - they often shut the door to private / hobbyist's orders after such a wave. kristal= has since then established a relationship with ALBS, so let's count on him doing a bulk order again.
  9. Not really: they have the internal interconnection such that turning them 90° makes for a very difficult trace layout on the PCB. However, I got curious: they do fit AS IS when you are comfortable with soldering only two legs and stuffing the other two in the additional holes for the Marquardt plastic noses. This way, the MEC switches sit on the board a little inclined rotated, at the 1pm clock position so to speak. The MEC's legs need a bit of persuasion, but it actually works. Unless you opt for non-circular button caps, then the whole arrangement will look a bit funny...
  10. Actually, triple footprints: Marquardt 6425 (my favourites, still searching for a STEP model...), ITT Cannon D6R (TK's favourites, on the right), and E-Switch TL1100 as used on Wilba's original MB-SEQ board (on the left).
  11. ilmenator
    BLM 16x4 v2
  12. From the album: BLM 16x4 v2
    © (c) 2016 ilmenator
  13. ilmenator
    BLM 16x4 v2
  14. Good to hear. If anybody else needs pre-programmed PICs just let me know. I have just found my Willem programmer in one of the cardboard boxes left from my last removal.
  15. Where are you located?
  16. Ziemlich einfach - es gibt mindestens drei Gründe dafür: A) Für die meisten MIDIboxer macht es Sinn, mit der "neuesten, schnellsten" CPU zu starten, weil sie nicht genau wissen, wohin sie die Reise führen wird. Wenn sie mit dem selben Core später mal eine anspruchsvollere Applikation bauen wollen, dann steht dem nichts im Wege. Irgendwann kommt ein neuer SEQ, und ob dann der F1 Core noch für alles reicht? Preislich sind die Unterschiede gering (und ja, auch ein Unterschied von 100% ist "gering" bei einer Stückzahl von 1). B) Für die erfahrenen MIDIboxer macht es Sinn, sich auf eine Plattform für den "Support" konzentrieren zu können. Bei vielen unterschiedlichen Plattformen im Umlauf wird es schwierig den Überblick zu behalten wenn spezifische Fragen aufkommen. C) Für Tim/SmashTV macht es Sinn, sich auf eine Platine konzentrieren zu können, weil damit Lagerhaltungskosten reduziert werden, und damit letztlich die Gesamtkosten für ihn und uns. Viele Grüße ilmenator
  17. Interesting... what's the schematic you're using?
  18. You're welcome, it's nice to see that there is still some interest in this project. Unfortunately, life got in the way back in 2014, before it was 100% complete. Let's see how far we get this time
  19. Hi there, currently the matrix does not allow for channel routing and event filtering. At the documented design stage, this would have only been possible for those inputs routed through the STFM or the (external) mergers (PIC 1688) anyway. Why? Well, everything that is related to routing is happening inside the FPGA, which is kind of "brainless". It is controlled by the STFM. In order to modify MIDI data in any way, that data would have to be routed through the STFM first, which is difficult: there are not enough available IO pins on the STFM board left. You could probably implement event filtering for two or so MIDI ports... USB MIDI has not been considered. But: you might expect a v2 later this year which has a virtual processor running on the FPGA. With this it should be possible to do some channel routing and event filtering, at least for a limited number of ports - depending on the number of UARTs that can still be implemented on the FPGA. However, this will not be a top priority. The main reason for the update is to increase MIDI port count to 64x64 and to make better use of the available real estate. It also means that the matrix itself will no longer be strictly MIDIbox based. The UI, however, will still be. And the whole thing will still be scalable and modular. Best, ilmenator
  20. ilmenator
    EA LPC1769 Revision
    Why three times the same image?
  21. Sure, there should be a PIC based software in the repository. I built a MIDIbox version of the Stribe a few years ago, so I can confirm that TK's implemenattion is fully functional.
  22. Superb! You should get paid by Novation for making their products more attractive...
  23. So, did you change the Launch Pad Pro's firmware or did you modify the MIDIbox Seq V4 to get this to work??
  24. It would help if you posted your location. A local builder is definitely something you want, in case the build runs into problems afterwards.
  25. My personal opinion: Mutable Instruments Ambika with 4P filters.
