2,305 -
37
Hi Drew, no, you're allright - they have been available middle of January when I last checked, but apparently they are sold out again. Given how fast they went I would assume that Tim is restocking them as fast as possible.
[SOLVED] Can't make two OLED LCD's working together
ilmenator replied to cube48's topic in Testing/Troubleshooting
You can do that yourself, just edit your initial post! -
But that again is almost more expensive than the display including a carrier board! OSHpark make great quality board and I recommend them wherever I can, but they are only cheap for prototyping a small number of boards.
SmashTV Core STM32F4 + MIDI_I/O Module PCB
ilmenator replied to fundamental's topic in Parts Questions
Thanks! -
Tim!Mike, do you have a part number available for those front panel mounting brackets that can be soldered to the two boards above? -
That's a bit on the low side - try something in the 10k range or higher.
Great support - really! I'm just saying this since I don't even remember when we moved to the ARM Cortex core and left the PIC world behind... For the MB6582: I guess only updating the "main" PIC which handles the UI is enough and doesn't break the interplay between all four? Best, ilmenator
I guess this is true for most, i.e. 99% of the units that have been built :rolleyes: .
IIRC there were some problems with (the packaging of) some of the cases, is yours in perfect shape/state?
Yes. Use BLM-Scalar or BLM-X code. It's in the repository.
- 13 replies
- PCB
- LED matrix
(and 1 more)
Tagged with:
Right, days are getting shorter again, but I have been relocating over the last weeks, and in my new place winter is not as bad as it used to be where I was before... Now seriously, the project is not dead, but I have to admit that I will probably not finish this in the next half year or so. New job, new country of residence, lots of other responsibilities - you get the picture. However, the WS is still clearly my favorite synth, so this WILL happen, eventually. Thanks for your interest and your patience. Any news on the project will be in this thread. Kind regards, ilmenator
The current status is documented in the Wiki, and jojjelito has a set of boards and FPGA core to do some beta testing. I am currently relocating to another country, hence the extended period of silence and lack of recent updates. It will probably take me until after Christmas until I have my workshop up and running again. However, the unit is basically working the way I intended, and jojjelito volunteered to do some torturing tests. Best, ilmenator
Nein. Aber hier ist der Schaltplan, und das Layout ist nicht allzu kompliziert - TK hat den ersten Prototypen auch auf Lochraster gebaut. Ob das allerdings den Aufwand lohnt, weiß ich nicht - ich würde einfach die fertige Platine von Tim aka SmashTV ordern.
That should reverse the pinout, so you need to be extra careful to get it right (unless you do the same on the target board as well).
You could modify the headline of your first post, adding a [solved] so everyone knows this has been fixed already!
Sh##t, I just realized these are not the regular MIDIbox SEQ4 ones but the MI Shruthi ones, right? I have to retreat then, I'm afraid. I am truly sorry for the hassle...
Me! I'll send pm later today.
I think that is a wise decision for now. I have sent you a PM. And yes, a few full kits are still available.
Yes, this data sheet looks ok. And no, it cannot be fixed in software. You might cut some traces and run little wires instead, but this would require you to understand the schematics and find the right traces on the PCB - and then figure out where to cut them for least effort.
